Oil leak and cannot find it 65 289
Old Jun 6, 2005 | 11:06 AM
tricksixtyfive's Avatar
I got a nasty oil leak coming from the area of my tranny and engine can't figure out where it's coming from and really need to fix it.
Anyone have suggestions
Old Jun 6, 2005 | 12:12 PM
chemeng's Avatar
I had the same problem, the flywheel inspection plate was always covered in oil. I replaced the oil pan and put on a new gasket set. Dry as a bone since thin.
Seems the ends of the oil pan has two rubber gaskets that compress over time and start to leak.
You don't have to remove the engine to replace either. Remove the crossmember, sway bar and remove the bolt on the idler arm. Cleaning the old gasket off is the bigget pain.
Hope this helps, MikeR
Old Jun 6, 2005 | 01:15 PM
66HertzClone's Avatar
Check the rear of the valve covers, sometimes a leak will develop there and run down the heads then the back of the block. It then collects on the inspection plate and appears to be a rear seal or pan gasket leak. Check the easy stuff first......
Old Jun 6, 2005 | 01:36 PM
I think it's the oil pan gasket, But i am getting insane quotes to fix this. I always get we have to lift the motor...I really don't know what to do..
Old Jun 6, 2005 | 02:07 PM
svopaul's Avatar
Service Manager
I can assure you that you do not have to lift the engine....drop the crossmember(2 bolts) and you might need to drop the steering linkage....you can then remove the oil pan. I've done this so many times over the years that I have lost count. This is something you can do yourself if you are mechanically inclined and take your time.
Old Jun 6, 2005 | 02:39 PM
pakrat's Avatar
Maybe I am living in a fantasy world, but don't they make an addative that you can put in the oil, run it for a while and then spot the origin of the leak via a black light?
just curious but I thought you did your own work on the car, what's with the price quotes anyway?
good luck.
Old Jun 6, 2005 | 03:32 PM
svopaul's Avatar
Service Manager
I don't recommend any of those snake oil leak detectors....much easier to clean all the oil off with Brake clean or Castrol Super Clean....run the car and watch for the leak to reappear.
Old Jun 10, 2005 | 05:54 PM
65fsbkhipo's Avatar
If it is a NASTY leak, how much oil are we talking about? Unless your burning oil through combustion, you'll be able to tell where the leak is right away. Pressure wash the engine and trans, run for a day then recheck.
dblhelx
Oct 6, 2015 08:08 PM
Rando
Sep 30, 2015 12:28 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Mustang65bob
Sep 21, 2015 11:30 AM
bconboy
Sep 18, 2015 08:18 AM
