JME gauge clusters
Has anyone bought one of these? I am looking at buying a bezel since I have the gauges already. They say that I need a harness, but the gauges (autometer ultralites) have what looks to be the appropriate harness goodies.
I should have been more specific. I am working on building a 6 gauge cluster and talked to JME about theirs. They said that I still needed the harness, but I can't figure out why. The autometer ultralites I have seem to come with all the needed equipment.
When I bought my JME cluster I purchased it without the gauges (or harness). I received just the aluminum cluster and instructions. The instructions included a nice wiring how to complete with color coding so you knew which wires to splice into for each gauge, light, turn sig etc. I still have the instructions sheet (which wasn't really used because I wired them using new feeds to the senders. Can't imagine why you couldn't do the same.
My Autometer Phantom gauges had the standard 3 wire + light hookup:
1 wire for sender
1 wire for ground
1 wire for ignition switched +
Small light:
1 wire light switch +
1 wire ground
1 wire for sender
1 wire for ground
Small light:
1 wire ground
