I6 to v8 swap?
Old Dec 19, 2013 | 09:39 AM
c68coupe's Avatar
I6 to v8 swap?
i am doing a v8 swap into my mustang, it was originally a I6 car, we are planning on leaving the suspension the same, to try and lower the nose of the car, but what will i have to change to accomodate the larger motor?
Old Dec 19, 2013 | 02:01 PM
LivinTheStangLife's Avatar
As far as I know not really much of anything as long is its a year that had whatever engine you are putting in. I would look at upgrading to v8 suspension to handle the weight. The suspension might look good sitting lower with the v8 in there but it won't handle the weight. Just my 2 cents. Have fun playing around with it
Old Dec 19, 2013 | 02:12 PM
AlsCobra's Avatar
A Man Just Needs Some....
Motor and trans mounts. Possibly driveshaft. You should be able to make everything else work. Make sure those front drum brakes have been changed to disks.
Old Dec 25, 2013 | 12:24 PM
c68coupe's Avatar
disks are in the works, and stiffer suspension will be bought.
Old Jan 3, 2014 | 08:35 PM
Juggalo586's Avatar
I'm finishing up this swap on my 65 hopefully this weekend. I put a 302 in mine. Everything I have been told from some mustang experts around me have said my suspension and rear end will be fine. They said just don't floor it. If you want to drive like that then upgrade it. Pretty much everything under the good has been replaced. I kept my c4 transmission. Also I am having a difficult time finding headers that will fit. Once the engine is dropped in you have about 3 inches between engine and firewall. You might just want to look into exhaust manifolds.
Ray11
Sep 25, 2015 12:43 PM
Grabber5.00
Sep 13, 2015 06:53 AM
