i have a u-joint question
Old Dec 8, 2004 | 08:42 PM
bigdixie's Avatar
I just got home and went to the parts store and all they had were joints for autos. I know the front and rear are different but what is so different about MT to AT. Can i use the ones for AT?
Old Dec 8, 2004 | 09:09 PM
Jay's Avatar
Jay
The difference is going to be in the rearend/yolk you have. You are replacing the front right? Take the old one with you, that's the important thing to match to correct size you have on there.
Old Dec 8, 2004 | 10:44 PM
bigdixie's Avatar
now i have not replace the front one yet. The front one is fine, the rear is the one that snapped on me. Are the rear and front the same size cause i was thinking about taking the front one out and taking it to the parts store and measuring them
Old Dec 9, 2004 | 08:55 PM
copasspupil's Avatar
Ford u-joints are either 1310 or 1330. 1330 being the larger of the two and usually only used with 9" rear ends. BTW, not all 1310's/1330's are the same. This is very important. I just went through this with my aluminum driveline.
If you can't bring in the ujoint, you need to get the diameter and length of the ujoint of each side. Also, I would recommend that you replace both if you going to do it. Besides what's 12.00 bucks anyway...It's got to be worth someone time.
Old Dec 12, 2004 | 09:09 PM
bigdixie's Avatar
well i had to put it in the shop cause when the shaft dropped it cracked the yoke. geez...oh well stuff happens. I appreciate your responses on the issue.
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
