Hiding the Wiring Harnesses
Just something to think about. My favorite type of mod - CHEAP, easy, and subtle. Had several people just stand and stare trying to figure out what was different... B) (Of course, they do that a lot with my car - not sure if that's good or bad! )
After 3 days of sitting in the dust at Nashville, I started trying to clean the engine compartment. Of course, for a good cleaning, you unclip the wiring harnesses from the engine compartment and clean under them. One thing led to another, and I ended up with everything stripped from the walls, and repainted.
After some :scratch: and careful measurement, I determined that 75% of the wiring can be hidden in fenderwells with only 2 wires needing cut (the 2 small solenoid wires). Really pretty easy to do, and a WHOLE lot easier to keep clean now. Some good wire wrap is recommended to help protect the harnesses, but it's "easy stuff".
If you're in "the build stage", you can weld most of the holes closed. I got plastic plugs from the hardware store and painted the heads semi-flat black. Not noticable, and the harnesses can easily be put back stock later.
Moved the solenoid and headlight/fan relays up beside the radiator. If you wanted to go crazy, a cover would be easily fabbed, and the firewall wiring could be hidden also. I didn't want to work THAT hard...
Here's some pics - enjoy!
If I were starting from scratch, I'd put the relays under where the battery try mounted, and move the solenoid down as low as possible. Then, make a "quicky" cover for the top of the framerail that would hide all of it & that wiring also...
Originally posted by BLAKE@June 15, 2004, 12:51 PM
I have also seen where someone used PVC pipe as a conduit in the fender well to protect the wiring.
You actually run it pretty close to the stock location - just on the outside. In some places I actually used the stock harness retaining clip holes - pushed in from the outside.
Originally posted by jpony645@June 15, 2004, 1:43 PM
That really makes me want to hide all mine while I still have the engine all out. Did you just run along the inside of the frame rail or what? I can't really tell.
Originally posted by jpony645@June 15, 2004, 1:25 PM
How are you getting them to the outside of the apron from the firewall plug?
Wow, that is a really clean wiring job. Looks great. I just finished custom rewiring my entire car. In the engine bay I used black flexible pvc tubing to cover all my wires, but it doesn't look as clean as yours does. Nice job
Originally posted by GT350Clone@June 19, 2004, 2:40 PM
Hey gp - good to see you over here. Been following the thread on SN about all the extra "noise" - good to see you here. How about inviting Oz???
I was telling Blake how funny it was that I just read a thread on VMF last week asking where cloney, jay, and emberglow went.
