HELP
Old Mar 28, 2014 | 10:20 AM
izaacrudd's Avatar
HELP
My 65's carb is still dripping gas after I shut the car off?? Now it is smoking a bit from inside the carb. And it won't start.
It is pretty much out of gas I think. Gas gauge doesn't work. What do I do??
Old Mar 28, 2014 | 10:24 AM
izaacrudd's Avatar
I also had it warming up on the driveway and opened the hood to see gas coming out of the bottom of the carb..
Old Mar 28, 2014 | 10:26 AM
izaacrudd's Avatar
Last two times I filled it up with gas I filled with unleaded. Later to find out it required premium.. Could this be the cause of some things?
Old Mar 28, 2014 | 01:02 PM
I don't think the type of fuel would matter with a leak. I would pull the carb off and replace gaskets and make sure all fittings are in tip top shape.
Old Mar 28, 2014 | 01:51 PM
izaacrudd's Avatar
I just had the carb completely done.. Can't believe it's already having problems -.- but I have loose bolts where it was leaking!
Old Mar 28, 2014 | 06:38 PM
Juggalo586's Avatar
If you had loose bolts then you should just have to simply tighten them down a bit. Just don't over tighten them or you'll ruin the gasket.
Old Mar 28, 2014 | 07:18 PM
izaacrudd's Avatar
Thanks. Tightened them and the leak stopped. Hopefully that's all that was the problem.
Old Mar 28, 2014 | 07:26 PM
Glad you found and fixed the leaky accelerator pump. Those are screws.
Old Mar 28, 2014 | 07:57 PM
izaacrudd's Avatar
Should it always be pressed in a little bit? Because I can stil manually release it more.. And why was it squirting gas into the carb after I turned it off?
Old Apr 8, 2014 | 04:17 PM
The accelerator pump is a manual device operated by the gas pedal (or by hand at the carb) - it doesn't matter if the key is on or off. When you first give a carb throttle, there is a lag for the fuel mixture through the jets in the ventura. The spray from the accelerator pump makes up for that so the engine increases rpm smoothly without a hiccup.
Whoever did your tune up and carb rebuild needs a good butt chewin!! I'm guessing you had it done before you moved to AZ...
Old Apr 15, 2014 | 09:43 PM
izaacrudd's Avatar
Originally Posted by cdynaco
The accelerator pump is a manual device operated by the gas pedal (or by hand at the carb) - it doesn't matter if the key is on or off. When you first give a carb throttle, there is a lag for the fuel mixture through the jets in the ventura. The spray from the accelerator pump makes up for that so the engine increases rpm smoothly without a hiccup. Whoever did your tune up and carb rebuild needs a good butt chewin!! I'm guessing you had it done before you moved to AZ...
Yeah I Had it done in Oregon.. $3,000!!!
