gt exhust tips - Yes or No?
Old Jan 8, 2005 | 11:22 AM
tricksixtyfive's Avatar
Thumbs up
I currently have open ended exshaust tips and love the look of the original gt tips. I bought a pair but i am afraid of losing horse power. will i lose to much by putting the gt exhaust tips. anyone know the answer to this....
Old Jan 8, 2005 | 12:47 PM
one2gamble's Avatar
the answer is no you wont
Old Jan 8, 2005 | 01:32 PM
65sohc's Avatar
Maybe, maybe not, but probably yes. How's that for an answer? It depends on where the most restrictive point is in your exhaust system. If you have nice 2.25-2.5 inch mandrel bent pipes, then putting a 1.75 in. louvered bottleneck on the end will certainly restrict flow. On the other hand if you have the more typical 2-2.25 in. system that was made on a muffler shop pipe bender, it probably necks down to less than 2 inches where it bends over the axle any way, in which case the GT tips would have a minimal effect. It also depends on how much power your engine is putting out. If it's an average 289 that's making 150 realistic horsepower it isn't pushing out all that much exhaust. By the same token if it's cranking out some serious power it is producing a much higher volume of exhaust which makes backpressure a more signicant issue.
Old Jan 8, 2005 | 02:27 PM
Dan66's Avatar
Yes, you'll restrict your flow to some extent - but what you may not be barganning for is the sound. Those louvered ends give a none-too-appealing "pht-pht-pht" sound. They take the nicest low rumble and give it a lisp. You can open them up a bit with a flathead scrtewdriver, but you can't get rid of that whispy sound altogether.
Imagine you were a horn player and had spent a great deal of money on a fine trumpet that had a true, rich sound. Would you put a louvered cap over its end leaving only thin slits for the music to come out? And if you did, would you expect it to sound the same?
Old Jan 8, 2005 | 03:04 PM
Well my motor isn't anything over 250hp so i guess slapping a pair of those will not make much of a difference thanks for the input fellas
Old Jan 9, 2005 | 05:48 PM
2bav8's Avatar
On a stock to mild motor you're not really going to be hurting anything.
Start bumping up the power and it would become an issue though.
I do agree with the sound issue though, it sounds kinda funky B)
My '66 coupe has a GT valence and I found that using chrome tips was a nice alternative to the trumpets IMO. Of course, my not-so-mild V8 would choke to death with those things too
Old Jan 10, 2005 | 09:18 AM
BLAKE's Avatar
Agreed.
I love the slick, thru-the-valance look, but the stock trumpet configuration leaves something to be desired in both sound and looks, IMO.
Old Jan 10, 2005 | 01:07 PM
pakrat's Avatar
:scratch: I seem to be recalling a thread not to long ago about someone customizing the tips? yes/no??? They angled the back and cut out the fins to get the look and performance out of it. Wasn't it this forum?????
Pak.
Edit: Lol, found it pretty quick, for what it's worth.
http://forums.bradbarnett.net/index.php?sh...11327&hl=gt+tip
Old Jan 10, 2005 | 01:08 PM
LMan's Avatar
I think that was Dan66, no?
________
PAXIL SETTLEMENTS
Old Jan 10, 2005 | 01:17 PM
hmmm this means i have a set of trumpet for sale cheap i'll keep my open end pipes.
If you look at 442 trumpet tips they r shaped the same but have open ends.
Anyone need a set of trumpets cheap?
Old Jan 10, 2005 | 01:49 PM
BLAKE's Avatar
Indeed it was.
Old Jan 10, 2005 | 11:38 PM
65sohc's Avatar
How about a pair of '70 Mach One exhaust tips from National Parts Depot: $329.95!! They look like they were crushed in a vice.
samjluck
Sep 17, 2015 10:24 PM
Sep 10, 2015 12:44 PM
GMAYS
Sep 10, 2015 06:19 AM
earl610
Sep 6, 2015 05:48 PM
whowasthat
Sep 3, 2015 08:48 PM
