Engine question
Old Sep 8, 2008 | 08:11 AM
Autotooner's Avatar
My C/T is cooler than Arin is.
Engine question
My friend has a 65 or 66 Mustang, and we need to know where to find the numbers on the block and body to make sure it is "numbers matching" I know the 71? and newer have part of the vin stamped to the block...
Old Sep 8, 2008 | 08:44 AM
houtex's Avatar
Near the starter. You may have to pull the oil pan to get some of it.
Here's the google search I did to pull it up... maybe it'll help you more for others numbers?
http://www.google.com/search?hl=en&q...66&btnG=Search
Old Sep 9, 2008 | 04:08 AM
ravenblack67's Avatar
Pull the starter to get the casting number for the block. Pull the valve covers to get the casting numbers for the heads. Numbers matching usually means the door plate and the vin stamped on the various body parts match. The casting numbers will get you close but they will not prove it is the original engine.
BavarianStang
Sep 5, 2015 05:55 AM
Sep 2, 2015 07:33 PM
