Engine block help
Old May 28, 2017 | 12:11 AM
66stang66's Avatar
Engine block help
So i found that I had a valve cover gasket leak and that lead to finding rusty rocker arms, springs and push rods. After taking the heads off I found rust in the block and was wanting some suggestions on what I should do. Take it out and have it cleaned or just keep running it?
Attached Thumbnails Engine block help-18742555_10208375028802890_857060094_o.jpg   Engine block help-18742562_10208375029242901_1673263896_o.jpg   Engine block help-18745133_10208375028682887_948775301_o.jpg   Engine block help-18767270_10208375028602885_1551312197_o.jpg   Engine block help-18788965_10208375028562884_280575197_o.jpg
Old May 28, 2017 | 11:24 AM
HOSS429's Avatar
legacy Tms Member
the dodge truck i once owned had a terrible case of that brown gunk in its engine .. i had the radiator cleaned and flushed it a few times and kept on trucking .. what year is your engine ? i see hold downs on the lifters for a roller cam .. just wipe out all the gunk from the holes that you can and take a good look at your radiator ...if you are concerned about the condition of the engine now would be a good time for a rebuild ...
Old May 28, 2017 | 11:36 AM
66stang66's Avatar
It is an 87 302. I have had the radiator flushed before but the radiator looks the same just not flaking off. Did a compression test and all of the numbers came back good. I don't know much about engines but my exhaust pipes and smog ports also have rust spots.
Thank you
Old Jun 25, 2017 | 07:33 AM
kennyg's Avatar
Do it right and take it out and rebuild or find a 289 to build and put back in. Get a new radiator and heater core while your at it so the 'gunk' doesn't pollute your 'new' engine.
Old Jun 27, 2017 | 07:50 AM
Greg G's Avatar
Get a Prestone Flush kit. Install the T. Plug the yellow "L" into the radiator. Hook a garden hose to the. Run cold out of the spigot of hook to the drain valve on your hot water heater. Turn on valve, water will shoot out of the "L" plugged into the radiator. it Might help. It is cheap to try
