Carburetor ??
Old Oct 21, 2006 | 08:40 PM
OUPony's Avatar
Carburetor ??
My 1968 has a C5ZF-D Carburetor by Ford, which I believe is the Autolite 4100. My online research tells me this was a carburetor used on the 64 1/2 - 66 models.
This makes me think the carburetor is not the original carb equipped on the car. Is this a fair assumption?
I need to order a rebuild kit because there is oil that is pooling on top of the block just below the carb and I want to get the correct kit. Either that, or I am going to replace the whole carb.
I am not a mechanic by any stretch, so any advice is appreciated.
Thanks.
Old Oct 21, 2006 | 11:53 PM
Ethan's Avatar
Id just buy a whole new carb.
Old Oct 24, 2006 | 12:10 AM
Bulldog66's Avatar
This may help some. ( best I can do in short order, I was heading to bed when I read this )
http://www.thecarburetorshop.com/Kmercury.htm
http://www.thecarburetorshop.com/Carbsale.htm
http://www.network54.com/Forum/88781/
http://ebay.partschoice.com/carbs/ca...ord/index.html
Old Oct 24, 2006 | 10:16 AM
OUPony's Avatar
Thanks for all of your responses. I was able to buy the correct kit from a local auto parts place and replaced the base gaskets and the pump diaphragm was leaking fuel, so I replaced it to.
It is running strong and no leaks.
MrSylphie
Aug 18, 2015 08:40 PM
Mystang68
1971-1973 Mustang
Aug 9, 2012 09:05 AM
rio87
Nov 17, 2011 02:22 PM
VintagMustang302
Oct 28, 2005 12:43 PM
