65 mustang light bulb question
A few inches below the ignition is a light bulb that I can't get to turn off. As soon as the battery cables are connected, the light turns on. I've tried every knob around but just can't seem to figure this out. (Can definitely tell I'm new to working on cars)
pull the fuses one at a time and see does it go out ..and is it just hanging there ?
twist the headlite switch back and forth .. you can turn on the interior lites with it .. and remove or unplug the door lite switches .. the ones that pop out when you open the door ..
2 Attachment(s)
These are 2 angles of where the lightbulb is. I've tried all knobs again and still no luck. Only way out as of now was to disconnect the bulb
1 Attachment(s)
And here's the slot the bulb came out of. (Sorry it's not the best of pictures)
Yup it's an interior light bulb..they both come on if u rotate all the way to the right I believe..it should turn of if u rotate the headlamp knob towards the left
Faulty door switch? Man I miss my 65 gt....
i guess you need to find another car like yours and look at what makes it come on in that car .. my 69 does`nt have that lite .. but it is def an interior lite which only comes on by opening a door or turning the headlite switch .. does your dash lites brighten and dim when you twist the headlite switch ? ..
Originally Posted by KeavDog
(Post 6464015)
There should also be one on the passenger side. When you turn the headlight switch knob all the way counter clockwise you should feel a detent. When you pass that detent the lights should both come on (if doors were shut). It does sound like you have either a faulty door switch (on the a-pillar at the front end of the door) or a short to power (the light fixture is always grounded). If you have a short to power it will always light but it is such a short (distance!) circuit that is unlikely. Have you tried unplugging the switch? Disconnect the battery then pry the switch out and unplug it. Does the light go out? You also have one on the pass door.
After you unplug the switch reconnect the battery! Then check light. Careful not to let the connector short to ground while disconnected
