427 Windsor 460 HP
Old Jul 17, 2013 | 10:30 PM
HEADACHEZ's Avatar
427 Windsor 460 HP
I am going to be pulling the trigger on this engine soon. However I have a couple of questions. I plan on using an AOD tranny but I'm not sure which company or setup I should use? I know that I must have at least a 2000 stall converter. I also am unsure of what rear-end setup I should use, right now I just have the stock 8". Would it be wise to just rebuild the 8" or use completely different rear-end.
Here is the link to the engine: http://www.smedingperformance.com/fo...orsepower.html
The car is a 1967 Mustang Coupe
Old Jul 19, 2013 | 11:57 AM
LCC's Avatar
LCC
You have to upgrade that 8". Not too bad though, get an upgrade 8" posi unit from auburn or a detroit soft locker. I believe you can buy these from jegs. Now if you want to do this on the cheap, Mustang II's had a posi 8" diff in them, from what I remember. Junkyard time. As for the trans , what I did is talk to a reputable tranny shop and they should be asking you the approximate HP and weight and gearing of your car for the correct torque converter. Who I use is http://www.lentechautomatics.com I can only comment what I have in my car and can tell you that I have zero issues with mine for 15 years.. There are other, just as good, trany builders out there.
Old Jul 23, 2013 | 07:51 AM
Dyno68FB's Avatar
With that amount of HP I would ditch the 8 and go to an 8.8 or 9. I got one from a guy on Craig's list who parts out cars who sold me a 9 in out of a 69 for $350. Two 31 splines from jegs at $99/each and an Auburn center for $450 to add posi and I have a great rear that will hold up to that Hp. Don't waist your money on the 8. Step up to a 9
mustangsally_
Sep 18, 2015 05:35 AM
AFBLUE
05-09 Exterior Modifications
25
Jun 23, 2005 04:49 PM
Jay
Sep 3, 2004 09:27 PM
