1967 Coupe 289 Overheating on the highway
Old May 2, 2012 | 11:42 PM
Originally Posted by houtex
Depends on the carb. Some, it's float level, others, it's jetting, others still, there's an adjustment screw... you just simply have to read the manual, if you can find it, for your particular model carb. I'm sure there's plenty in Google.
Keep in mind the adjustment screw is only for the idle jet/mixture.
The only way to check the main jets is to check the color of the plugs. Don't remember if I was told or read it in one of my old manuals, but the best way is after the engine is good and warm, to pull a long grade, pull over and shut off quick so idling doesn't carbon them up, pull plugs and look for that nice tan color.
Dark/black = jets are too rich (big). Totally white out = jets are too lean (small). Change one jet size at a time until you get that nice tan color.
Gawd I love old school! F that ECU/SCT crapI!!
Old May 3, 2012 | 07:20 AM
mhaymes67's Avatar
Wow. Lots of info.
I'm going to check out my transmission first. Sounds like a reasonable explanation since the engine seems to be running smoothly. Can I check the temp on the tranny with a laser thermometer, and approx what temp should it be? Then I'll start everything one by one.
Old May 3, 2012 | 07:22 AM
mhaymes67's Avatar
And I'm pretty sure it's a 3 core radiator, but looks real thin. Def not 1" rows. Only about 2" thick. $300 for a 4 row aluminum radiator isn't really in my budget right now, but I'll get on it asap.
Old May 3, 2012 | 07:23 AM
mhaymes67's Avatar
No A/C
Old May 3, 2012 | 07:30 AM
mhaymes67's Avatar
Also it's an automatic. I'm going to do the rpm/speed test today when I finish work. I'll get back with the results as soon as I know something.
Let me get this right. I should run it in first or secon for a period of time at higher rpm's and see if it gets hot?
Old May 3, 2012 | 08:20 AM
Kinyodas's Avatar
Houtex said. "...The exhaust going quiet at the 65 MPH mark is... disturbing..."
My 69 Galaxie w/ new duals did the same thing, went quiet from 65-70 & I never had an overheating problem. Sounds can 'cancel' out each other if the pitches are right. Weirdest thing ever was when I sat idle next to big city diesel bus, you could not hear either exhaust. Eerie silence.
Old May 3, 2012 | 08:27 AM
houtex's Avatar
If it's a 3 speed auto, then yes, 2nd at the SAME RPM. You are trying to determine if the speed or the RPM is the key to this whole thing.
If the car runs at 3000 RPM at 65MPH in 3rd, then put it in second and run down the road at, oh, 40 @ 3000RPM, or whatever the MPH winds up being.
That being said, just now, I realized that it could be the 3rd gear in the trans doing it, so the test won't do anything to say RPM or speed, but I kinda doubt it, I bet this does something to help you figure it out.
I hope.
Old May 3, 2012 | 09:07 AM
mhaymes67's Avatar
Everything seems to shift smooth and runs great... Just gets hot. Heating up faster now that it's hot outside.
I'll keep you posted.
Old May 3, 2012 | 09:12 AM
mhaymes67's Avatar
I'll also take note of when it shifts (at what speeds) see if that helps
Old May 3, 2012 | 09:47 AM
mhaymes67's Avatar
Is it possible that the 3 spd auto tranny in my car has overdrive? Would that explain the quietness at 65? If so, how could I look at it and tell? It was originally 6 cyl and manual shift.
Just a thought...
Old May 3, 2012 | 09:52 AM
mhaymes67's Avatar
Anyone know of a good mustang guy in the Atlanta area??? I think I need help. Haha
Old May 3, 2012 | 10:01 AM
Kinyodas's Avatar
Any general mechanic should do, especially if they're old school - I'd find a lot that 'missed the old days' and loved to touch antiques. I don't think you necessarily need a Mustang guy (or girl).
Did you by any chance check for water flow? I don't remember seeing it mentioned.
Old May 3, 2012 | 10:08 AM
mhaymes67's Avatar
I checked the water flow. I just got it warm and, with the radiator cap off, I revved the engine. The coolant moved about 1/2" when I hit the throttle. Enough?
Old May 3, 2012 | 05:09 PM
mhaymes67's Avatar
Well boys. It's raining. Just got off work won't do much good to do the speed/rpm test tonight.
One thing I did figure out:
If I drive it in 2nd gear exhaust gets quiet at approx the same rpm range. Not sure what that means, but food for thought. Haha
Old May 3, 2012 | 07:28 PM
mhaymes67's Avatar
http://www.cjponyparts.com/radiator-...1969/p/RADA33/
Does this radiator seem sufficient to cool my engine?? I know it's still a 3 row and it's 2" thick, but it's aluminum...what do you think?
Old May 4, 2012 | 08:33 AM
Kinyodas's Avatar
What mix are you using for coolant & how old is the radiator?
Old May 4, 2012 | 08:43 AM
mhaymes67's Avatar
I'm using 50/50 coolant to water and the radiator is less than a year old...
Old May 7, 2012 | 07:51 AM
mhaymes67's Avatar
New water pump going in today. I'll keep you posted.
Old May 8, 2012 | 06:04 PM
mhaymes67's Avatar
They gave me the wrong water pump! **** you "Auto Zone"
I'm giving in and taking her to a "real" mechanic in the morning. I'm spending more money trying to figure it out. I'll let a professional see what they can come up with. I really hope these guys can figure it out. The owner of the shop drives a very nice '66 Mustang. I hope that translates into me getting out on the highway soon!
Old May 9, 2012 | 10:08 AM
  #40
Kinyodas's Avatar
Wrong pump? Get the right one! Easy-peasy.
Blades too small or something? How'd that happen?
