1966 Ford Mustang Coupe Build Chronicle w Engine Upgrade!
#328
Good deal! I'd like to see what it looks like with the new tires and wheels.
It's pretty nice outside here today. I'm going to go down and get mine washed and drive it around a little bit........
#329
Well. I got them but it's becoming a PIA to flare the brake lines and they aren't coming off ATM so might be a day or two before it's on all 4s with functional brakes. =/. Nice. I wish it was nice here. It's hot as hell here and 100 times worse in the garage.
#330
Ok. I am now losing patience with this car. I put my tires on to see how it sits since getting my brother to cut the coils and I think the coils got cut too much or something else. happened. will upload a pic soon of what I'm talking about
#333
#334
How much did you cut the coils? New ones aren't very expensive are they?
Here's some for $80 from CJ Pony...
http://www.cjponyparts.com/coil-spri...1966/p/CS8531/
When you replace them it might take a while for the car's weight to settle the springs. My rear end was jacked up after I replaced the rear leaf springs.
#335
#336
I bought a set exactly like this except for 67-up.
http://www.cjponyparts.com/product.asp?pn=CSC656
I also sit 1 full coil cut off of them.
#337
Ok. Thanks for the links but I put them back on and had my brother check it out and he said he has his coils cut the same and I need a lower profile tire
#338
Ok, well i decided to get smaller tires for front. 195/60/15. hopefully be getting them soon. Solenoid switch went bad so had to get a new one and finally got to hear it start in i dont know how long. no to figure out what else is wrong with it
#339
That should work. I have 205 on mine I think. I had problems with the fender rubbing on the front tires when I had 225/60/R15. You can't trust everything you see on the web!
#340
No u cant. Gonna be getting break lines soon and bend my own so hopefully it will be ready to be driven by the time i get new tires. so much for getting an air scoop soon
