JLT 3.0 oil seperator won't fit. 10 gt
Hey everyone. I recently purchased a JLT 3.0 driver side oil separator. I took off the old pcv hose and tried for an hour but can't get the separator to fit its like there's not enough room for the canister to sit on top of the valve cover and the wires over there. Didn't turn out to be a plug and play for me.
All the pictures ice see the seperator looks like it has about a quarter inch or so of clearance under the can, mine seems like it has no clearance at all, the can can't sit straight up and down, it's more bothering that this should have been a 1 minute plug and play.
Received 1,498 Likes
hmmmm . . . it was plug and play on my 2010 GT, no issues . . . I wonder if you have a later version or something . . . later if I get a chance I'll take a pic
but don't worry about it too much, mine doesn't collect anything anyway
It almost seems like the canister itself is to big, If I unscrew the bottom canister, I am able to hook it up. But even if I do it that way, I can't screw the can on afterwards because there's not enough clearance to screw it on, it still hits the valve covers (cam covers).
Thank you for letting me know about the not catching anything part. I don't believe I could return it now since the bottom is a little scratched up from trying to get it to fit
Sorry for slow follow up . . . here's what mine looks like, installed.
It is a little tight, but it sits in there just fine. There is about 1/4" clearance on the bottom. It is a bit tight for access to unscrew it, but it can be done; just need to bend the hoses upward a little.
By the way I had the engine cover in the past, no problem. I removed it to make it easier to clean the throttle body (I have to remove the strut tower brace to remove the cover to remove the throttle body) plus I thought it might make the engine run a little cooler on the track.
Your cannister looks very similar to mine, except for the color, though it is hard to tell in pictures.
And here's what it collected after two track days . . . meaning over 2 hours of high RPM, heavy throttle operation. Definitely much harder driving than you will ever do on the street, unless you are completely out of your mind.
I was told that it needs steel wool inside, so the oil has someting to cling to. I did add some, but it did not make much difference. I still wonder if it is actually working right.
Sweet thank you for the reply. I finally got it after some slight movements lol. But heres the issue now, the hose that connect to the valve cover (The right side hose) has a huge depression in it from making it fit, literally it looks like only a small about of "air" can get through there its squished so much from the of the house. Nervous this will caught the valve cover not to breathe right ?
From your picture, it doesn't look like the right side of your can hose has any crease in it, almost like the hose is to long?
yeah, that does not look right . . . mine does not have that kink, fits perfectly though the space is tight . . . seems like maybe you got the wrong one, hose is too long?
I think I would call JLT if I was in your situation . . . these usually are small companies that are happy to talk with their customers and offer a solution if possible.
No offense to those running JLT separators, however when I first started out running oil separators, JLT was my first choice and although it did capture some of the crankcase vapor oil, it unfortunately didn't capture enough of it, in which quite a bit still got past the PCV connector at the intake manifold and then seeped out from the throttle body..
Needless to say, I then made the switch from JLT to Bob's autosports and then eventually from Bob's autosports to my current UPR 4 chamber catch can.. Both the Bob's and UPR cans have a much improved superior filtering design over the JLT and haven't noticed any oil vapors getting past the PCV barb connectors at the intake manifold whatsoever since making the switch..
Anyway just something you may want to consider looking into
http://www.uprproducts.com/mustang-b...all-11-sc.html
Thanks for the info, but . . . I am not convinced that it is needed on a N/A car, I don't think I'm going to put any more thought or effort into it until everything else on the list is done first.
Aha -- I see your car is supercharged, which creates more blow by and the catch can might actually be needed.
