2012-2013 BOSS 302
Turn downs
Old 5/23/16, 08:52 PM
mikes70mustang's Avatar
Turn downs
I know the side exhausts supposedly don't increase the flow. So. Has anyone or does someone make a kit to make the boss side exit only with no rear tails? Seems like it would be nice to have some tire warmers on it.
Old 5/26/16, 09:52 PM
Skrapmetal's Avatar
I don't know about turndowns... but the side pipes don't increase flow? Where are you hearing that?
With restrictor plates removed they do.
Old 5/27/16, 08:54 AM
ford20's Avatar
You would have to custom fab dumps as no one really makes a kit for them.
Old 5/28/16, 09:14 PM
I can't tell you for sure where I read it. I was researching if the exhaust flows with and without the plates. I read that the side exits are more like resonators and don't bring exaust pressure down.
Old 6/6/16, 04:31 PM
After getting a good look, the pipe itself in front of the tires is quite small. It would probably be beastly if those were swapped out for 2 or 3 inch pipes.
Old 6/8/16, 05:50 AM
Skrapmetal's Avatar
It is a bit small, but it does flow. Kooks makes a bigger sidepipe setup, I just wish the tips weren't visible on them. I kinda like the stealthy sidepipe thing.
Old 6/8/16, 12:37 PM
berzerk_1980's Avatar
I don't know if we're still talking about the performance changes with the Boss side pipes, but I have some dyno numbers from my car you may find interesting. It's a 14 GT with the Boss exhaust, GT500 ABs and the GT TracKey. Numbers are max torque/max hp. I used the same dyno like 6 months apart.
1. Stock: 344/364
2. Exhaust with stock calibration: 330/369
3. Exhaust with TracKey calibration: 350/394
On 3, the max number may be a slight overestimate, as the dyno sheet indicates slight wheel spin. So maybe subtract 5 lb-ft?
What I see though is stock for stock, the exhaust made minimal torque loss and minimal HP gain.
The sound, however, while not ear splitting, is extremely satisfying.
michaelkthornton54
5/16/16 10:10 PM
ddejesus052389
1994-2004 V-8
5/11/16 01:39 PM
Joeywhat
5/6/16 09:21 PM
Quick Reply: Turn downs
