2013 HIDs on a 2012 Halogen
Old 5/1/16, 01:01 PM
awoychosky123's Avatar
I have been working on buttoning up my 2013 retrofit on my 2012 and the last thing I need to do is swap the headlamps. Not only to look nice but the color difference between the 2012 bulbs and the led fogs are god awful. I know there are a few threads floating around but they died off, I really need information on the harness, Everything I need for them and where to obtain the parts. I already found the plugs and capacitors, Lexiion if you have any input it would be greatly appreciated.
Old 5/1/16, 07:14 PM
LEXiiON's Avatar
What ya need? There are 2 ways to go about that: Build your own HID conversion harness (I did that - not that difficult) or program your SJB to a 2013 SJB (or buy one off eBay for $70) and just add the wires according to the diagrams. The 2011-2014 SJB's are all the same... Halogen or HID all identical, it's the software that makes the difference.
Let me know what you want to do and I am willing to help you out. I actually have a 2013 SJB that you could use to try.
Or you go full throttle and buy a 2013 V6 light harness and a 2013 SJB and just replace the whole thing.... but $$
LEXiiON
awoychosky123 (5/7/16)
Old 5/1/16, 07:52 PM
I have all the stuff I need to program the sjb as i did the 2013 cluster swap, so we can try that.
Old 5/1/16, 08:03 PM
LEXiiON's Avatar
Ok. So you need to do the following: Wire the 2013 HIDs up as in the diagrams. Add two 20A fuses for the power (that is part of the BJB for the HIDs - no Software can fix that ) to the HIDs and the rest should be just easy.
LEXiiON
Attached Thumbnails 2013 HIDs on a 2012 Halogen-hids-2013.jpg   2013 HIDs on a 2012 Halogen-2013-turn.jpg
Old 5/1/16, 08:04 PM
If I do the SJB reprograming will that give me the LED switchback?
Old 5/1/16, 08:18 PM
LEXiiON's Avatar
Yes...
You don't even need to reprogram the SJB for the switchback. That's done through PIN3 at the HIDs. You need to reprogram the SJB for the high beams.. It needs to power the low beams when you are on high beams, as on the HIDs that's just a shutter solenoid.
LEXiiON
Old 5/1/16, 08:23 PM
What do you have in terms of as-built codes for me to use?
Also thanks a bunch I didn't even know where to start on this project.
Old 5/1/16, 08:31 PM
LEXiiON's Avatar
GEM 726-01-01 0A0A 43
GEM 726-02-01 03C0 2020 0033
GEM 726-03-01 0140 72
GEM 726-04-01 0234
GEM 726-05-01 040C 43
GEM 726-06-01 0000 34
GEM 726-07-01 2505 5F
GEM 726-08-01 0105 0A46
GEM 726-09-01 C000 F7
GEM 726-10-01 8008 0000 00C6
GEM 726-10-02 0000 0000 003F
GEM 726-10-03 0000 0000 0040
GEM 726-10-04 0000 41
GEM 726-11-01 1400 53
Old 5/1/16, 08:46 PM
Thanks a lot is there anything else I need to know? I am still waiting on my parts guy to get back to me.
Old 5/1/16, 08:52 PM
LEXiiON's Avatar
Nope. That should be it.
LEXiiON
Old 5/1/16, 09:04 PM
Thank you very much I will post when I get the assemblies in.
Old 5/5/16, 08:15 PM
Now can I used the 2012 turn signal connector or does that have to be changed too?
Old 5/5/16, 08:17 PM
LEXiiON's Avatar
It is a different connector. The 2012 won't fit.
LEXiiON
Old 5/5/16, 08:35 PM
Can I get the new connector right off of tasca?
Old 5/5/16, 08:39 PM
Never mind I answered my own question links if people need them
2013 Turn signal connector: http://www.tascaparts.com/oe-ford/3u2z14s411fhab
2013 HID Connector: http://www.tascaparts.com/oe-ford/cu2z14s411ada
Old 5/5/16, 08:46 PM
Lexiion should I reprogram the car before or after I hook the lights up?
Old 5/5/16, 08:49 PM
LEXiiON's Avatar
After. Shouldn't make a difference.
LEXiiON
Old 5/7/16, 12:35 PM
Will fuse 26 and 27 already have wires coming from them and just cut off somewhere, or will I have to add wires to 26 and 27?
Old 5/7/16, 01:39 PM
LEXiiON's Avatar
You will have to add them.
LEXiiON
Old 5/7/16, 03:38 PM
What about the parking light/turn signal I see that the turn signal bulb uses the same wires as the led appears to use. Did ford slip these wires so I have one for both the bulbs and the leds?
Quick Reply: 2013 HIDs on a 2012 Halogen
