daytime running lights from headlights to grill lights
Old 3/24/16, 09:35 AM
I-70 west's Avatar
Anybody done this ?
I want to change my daytime running lights from headlights to grill lights.
I have a 06 pony pkg
Attached Thumbnails daytime running lights from headlights to grill lights-img_1750-small-.jpg
SiBEERian (12/5/16)
Old 3/27/16, 12:16 PM
VGMStudios's Avatar
yes Ive done something like this. Ive changed my DRLs from headlights to Angle eyes.
Since Ive asked this before and figured it out myself since no one knew, Ill help you best I can... You need to by pass or reroute your DTL system. Reroute the proper wires to your fogs lights. Just know you wont be able to use your fogs light switch any more. I believe it is the Yellow wire that is your DTL uses that youll need to give power to your Fogs. You might also need a relay switch (I needed two of them) and a resistor but let me double check and get back to you.
Old 12/5/16, 05:56 AM
SiBEERian's Avatar
Originally Posted by I-70 west
Anybody done this ?
Hi! Greetings from Russia!
I solved this problem so:
http://www.mustangclub.ru/forum/topi...F%D1%82%D1%84/
Old 12/5/16, 05:59 AM
SiBEERian's Avatar
Old 12/5/16, 09:53 PM
stupidgenius36's Avatar
Nicely done. If I'm looking at that right, you basically just jumpered the fog lights to the fuel pump? Very simple and clean. Welcome aboard!
Old 12/5/16, 11:32 PM
SiBEERian's Avatar
Thank you. Yes, that's right. And it is always possible to return everything to the initial state without cutting wires.
Old 1/19/17, 07:25 AM
Jcreek79's Avatar
So how does that jumper setup, stop the headlights from activating as DRL?
Old 1/19/17, 08:24 PM
SiBEERian's Avatar
In my city there is no specialist who would be activated DRL in headlights.
rob19810
4/13/16 07:15 AM
mustang5o
'10-14 Exterior Modifications
4/1/16 10:00 PM
slufoot733
3/12/16 06:44 PM
Quick Reply: daytime running lights from headlights to grill lights
