Notices
Sponsored By:
Sponsored By:
Oil Cooler Installed
Old 5/5/12, 09:24 AM
Big Poppa's Avatar
The install took about two hours and added absolutely no horsepower or torque. I used regular hand tools and a small 0-50 in lb torque wrench. I changed the oil while I was doing this and it's about half a quart low. Should I fill it or just let it be?
Attached Thumbnails Oil Cooler Installed-dsc02122.jpg   Oil Cooler Installed-dsc02123.jpg   Oil Cooler Installed-dsc02125.jpg   Oil Cooler Installed-dsc02132.jpg   Oil Cooler Installed-dsc02133.jpg
Old 5/6/12, 02:08 AM
jsimmons's Avatar
Fill it.
Old 5/6/12, 06:44 AM
AzPete's Avatar
By adding the cooler, you increased the capacity of the system so you will need to be sure it is filled properly at all future oil changes, especially if you have a shop do it.
Old 5/6/12, 10:23 AM
David Young's Avatar
Yep, fill it. I've been thinking of adding this to my Mustang.
Old 5/6/12, 10:58 AM
RMS70's Avatar
where does the water come from? Do you have to splice into the cooling water lines?
Old 5/6/12, 11:58 AM
kn7671's Avatar
Edit: Looks like it gets water from the lower radiator outlet.
Old 5/6/12, 12:13 PM
Big Poppa's Avatar
It's a liquid to liquid cooler. The stock lower radiator hose is replaced with one that has two ports ( wish I would have took a pic of this) those ports have two lines that connect to the pump or whatever that thing is. As hot oil leaves the engine it passes by cool anti-freeze and and is returned to the engine cooler than it left it. We use the same principle on aircraft engines but we use fuel to cool the oil. In a aircraft you don't want your fuel to get too cold, hence the oil heats the fuel and the fuel cools the oil.
Old 5/6/12, 12:15 PM
Big Poppa's Avatar
The water never leaves the lower hose. The hot oil just passes by it.
Old 5/6/12, 12:25 PM
Big Poppa's Avatar
As you can see the first picture shows the stock hose. The 2nd shows the replacement hose with the oil ports. The 3rd shows the the supply and return lines connected.
Attached Thumbnails Oil Cooler Installed-dsc02126.jpg   Oil Cooler Installed-dsc02129.jpg   Oil Cooler Installed-dsc02134.jpg
Old 6/7/12, 07:29 PM
redneb's Avatar
Thanks for posting this. I have been thinking about buying one of these and installing it myself. Were you able to do this with the car on jack stands or do you have a lift? My 86 VW GTI had this style of cooler from the factory. Had a digital oil temp indicator too.
Old 6/7/12, 09:47 PM
amplifier28's Avatar
Where did you get the oil cooler from? How much did it cost?
Old 6/7/12, 10:44 PM
y5e06's Avatar
Is this the same cooler used on the Boss?
Old 6/8/12, 05:24 AM
Bucko's Avatar
Go here:
http://www.cjponyparts.com/product.a...paign=shopping
Old 6/8/12, 05:56 AM
BackinBlack13's Avatar
Originally Posted by Bucko
For 11/12's only? Or ok for 13's too?
Old 6/8/12, 10:38 AM
Big Poppa's Avatar
It can be done with jack stands, but so much easier with a lift.
Big Poppa's Avatar
Yes it is.
Old 6/8/12, 10:47 AM
Big Poppa's Avatar
Mine came from here, but it was not on sale at that time.
http://www.americanmuscle.com/frpp-b...oler-1112.html
Old 6/8/12, 10:48 AM
Big Poppa's Avatar
It will work on a '13
Old 6/8/12, 08:03 PM
FeedTheBeast's Avatar
Let us know if you see a difference in operating temperature -- under heavy load, or beyond the bounds of the thermostat-managed range.
I'm considering one for my late summer drive through Arizona.
Old 6/8/12, 11:57 PM
Big Poppa's Avatar
I wish I could and I understand your concerns but I do not have a oil temp gauge. I confident that it does what it is supposed to.
Quick Reply: Oil Cooler Installed
