The Best Time to Shift for Maximum Acceleration
TMS Editor
Do you know when is the best time to shift from one gear to the next?
Read the rest on the Mustang Source homepage. >>
ofequipmentgolf (10/27/16)
Okay I am little confused I grew up being told that each gear has its on sweet spot. I noticed that in first gear my car does not go any first faster past 4k rpm. Driving it to redline really does not do anything but make a lot of unnecessary noise. So have I been doing it wrong all these years or this DOC-TUBE-MENTARY a little off.
It's about setting up the car for the next gear.
If you have a car making peak power at 6000 and you shift at 4000, you're not getting the most out of that first gear, and you're setting up the car for the next gear with an rpm that's too low for that gear and therefore it will accelerate slower
Received 2,174 Likes
When seat of the pants feeling tells you the acceleration has started to flatten out you grab the next gear.
I suspect for most applications shifting at the redline is no happy coincidence, especially in a performance car and you can easily test this by going to the track and shifting at various points using your time slip as a guide rather than the butt dyno.
