Sponsored by:
Sponsored by:
Antifreeze question
Old 5/30/08, 05:20 AM
Clark Kent's Avatar
Antifreeze question
I could not find any yellow antifreeze like the one reccommended by Ford. So i topped it off the All makes Prestone antifreeze. Now I am worried after reading some information about problems arising from mixing antifreezes. What should I do? Could this cause damage to my engine? Or is it ok to mix in the universal stuff? If this is a problem how would I go about fixing it?
Please any help would be greatly appreciated
Old 5/30/08, 06:18 AM
Robbieg's Avatar
I would think that the "any makes any model" would be compatible with everything and safe to use. That's about all I could find when I did my S/C install so thats what I used although that was a complete drain and fill and not a mix or top off I still don't think it should make a difference. Short of getting it at the Ford dealer the options are getting pretty slim on the shelves.
Old 5/30/08, 09:22 AM
364's Avatar
The yellow is suppose to last longer than the green. By topping off with green all you are doing is shortening the length of time that the yellow will last. Just means you will have to change it sooner.
Old 5/30/08, 05:54 PM
Stoenr's Avatar
Could not find any Zerex G05? That stuff is all over the place.
Old 5/30/08, 07:12 PM
goldenpony's Avatar
Coolant
That's what I bought
Old 5/30/08, 07:49 PM
sound wave's Avatar
kind of on topic, but is that royal purple "purple ice" any good?
Old 5/30/08, 07:53 PM
karman's Avatar
Then you have factory.
You are fine except for the dye color.
It comes in different dye colors (ford is yellow).
http://www.englefieldoil.com/PDF/ZerexG-05QAs.pdf
Old 5/31/08, 04:51 AM
Mark S.'s Avatar
Dealers carry the Motorcraft Gold coolant...I picked up a gallon a few weeks after buying the car (in the event I need to top off the overflow tank)...and this coolant is supposedly good for 4 years.
I know that the 5 year DEXCOOL (which I have in two of my other cars) works like it advertises.
CNFLCTD
GT350
8/4/17 07:08 AM
MustangConvert11
9/30/15 08:01 PM
Quick Reply: Antifreeze question
