Get Your Hands on This 1967 Fastback and Own a Piece of History
This '67 Mustang is a wonderful blend of both new and original parts. It also holds the title of the only Fastback to be deployed to an active war zone by Ford in 1967.
War Zone
The 1967 Mustang pictured above is the only Fastback that Ford deployed to an active war zone in 1967. Now it's up for auction, and it comes with a Marti Report and a certified letter detailing its export.
Photos courtesy of Mecum.
Registry
This model is listed on the T5 Registry. It also has its original data plate with Vietnam stamped into it.
>>Join the conversation about this 1967 Fastback right here in the Mustang Source Forum!
Drivetrain
Under the hood of this Mustang sits a new small-block V8 powerplant, and the 289 ci unit appears period correct. The drivetrain, including the engine and transmission, has only racked up approximately 600 miles.
Stopping Power
Bringing this model to a halt is a new 4-wheel disc brake system. This new system includes new wheel bearings, so you can brake with confidence.
A Healthy Mix
This Mustang has taken shape with a healthy mix of both new and original parts. It features a new dual exhaust and mufflers with full tube headers. But its sheet metal and paint are mostly original.
It Drives straight
This model's owner recently fitted it with new wheels, tires, and suspension components. Its alignment was also adjusted, so you know this car drives straight and true.
Ready to Go
A lot of work has gone into keeping this Fastback fresh and in good working order. All of its electrical systems including gauges, lights, signals, heaters, wipers, and radio are in perfect working order. Could you be tempted to place a bid?
For help with service and mods on your Mustang, visit the how-to section of our sister site MustangForums.com
