Video: S197 vs S550 at the track
Received 2,171 Likes
Originally Posted by 5.M0NSTER
Few months now, but I think I i forgot post it here. It was a fairly even match to be honest.
I am not nearly as a good a driver or videographer as 5.MONSTER , but here is a couple laps on the NASCAR Roval at Charlotte Motor Speedway last Friday morning.
The S550 was lined up behind the pace car and I was next. I clipped off the pace lap and the first under green, so this begins on the second hot lap after tires and brakes were warmed up.
5.M0NSTER (4/24/19)
That looks like a fun track, your video just made me add it to my bucket list. Your line was better than the car in front and after you turn off the oval the walls get tight. Good car control. Thanks for posting.
The PP2 is an appealing package. I strongly considered it also. I’m still not a fan of the S550 stying so that’s the deal breaker for me. The only S550 I genuinely enjoy looking at is GT 350. I’m considering it actually when I get back to the States.
But it in all honesty the PP2 has impressive capabilities for very reasonable price.
What at is your goal for the car? Do you want to do track days or more spirited driving on the street?
Nice work EF1, looks like your driving and videography skills are doing just fine!
I am with 5.MONSTER on the looks of the S197 versus the S550. Also, my 2011 is paid for so it is easier to stomach if something happens to it at the track.
Assuming the cars are even close, its the driver.
My S197 is conservatively modded, and hangs very well with the big boys at PIR. Let me qualify that. It hangs with the big boys until the straights. PIR has two long straights per lap that I top out at about 130 (indicated). I will give point by's to the hi-end Camaros, the GT3s, etc... on the straights. And they go by hard.
My plan is to hold the S197. Keep modding it. And hold out until the mid-engine C8 Corvettes depreciate to a reasonable level.
Actually, the thing I like best about my 2012 (aside from it's just stupid fun) is that it's really not worth very much money. And if I toss it into a wall, I wouldn't be terribly upset. Now if I did the same with a new S550....
Great thread.
Be safe out there!
Great thread.
Be safe out there!
The S197 is very capable and will run with the S550's, especially with some suspension work. The deciding factor seems to be driver. I have at times run away from S550's and at others watched their tail lights disappear in the distance. There was a pro driver in a fox body American Iron car last week that absolutely smoked me.
Great thread.
Be safe out there!
Great thread.
Be safe out there!
Case and point, here is some recent video with my M2 from Spa Francorchamps and Hockenheimring. At Spa I was able to hold my own against Porsche's quite well. At Hockenheimring not so much. Those guys drive their GT2s and GT3s well and hard. And it shows. Fast car helps, but Driver all the way.
My first time at both tracks, so I have lots of improvements to make still, more so at Hock than at Spa. But that was a strange feeling at Hockenheim. My M2 was one of the cheapest cars around. By a large margin. Enjoy.
Oh, I see your dilemma.
I prefer the looks of the S197, but there are things about the S550 that overcome looks.
I'm probably more of a spirited rural road and expressway driver, with maybe a driving school and occasional track day. My biggest draw to the PP2 is the adjustable Magna-ride dampers at the touch of a button.This way I could have a softer ride when the wife rides with me, and a stiffer suspension when I'm by myself, and I don't have to worry about if it's adjusted right or not. If I upgrade to say the Ford adjustable suspension for the 13GT, the question is, do I have it adjusted for the best handling, not to mention will my wife still be able to ride in it with her arthritic back. My Mustang is a Brembo package, and we both enjoy riding in it, but I'd like a stiffer suspension, but it's about as stiff as she can stand.
I say that because the PP2 comes with a lot of GT350 parts, which are heavily track focused including 305 wide Michelin Sport Cups which will wear out in 6k miles or 3 track days.
What the Brembo equipped '13 GTs are missing is good damping. It's hard to get good damping in factory ride height on S197s, but if you're willing to invest in springs you have options. For what you want Ford adjustable shocks, or Koni yellows (which I've had) are not the right option because you have to play with it and switch settings depending on situation. Plus even in the softest setting they are always a bit harsh. But you can achieve less body motion (roll/pitch and dive) with springs and dampers. I could recommend either Steeda Sports with either Steeda fixed dampers, or Bilstein self-adjusting dampers. The second one will be more expensive, but best of both worlds. It adjusts by itself so you get good damping and comfort depending on the speed of compression/rebound. Either way you'll get comfort with better chassis dynamics. This will cost $2-3k in parts. PP2 will cost extra $20k+ over your 2013.
Of course S550s come with more tech, so it's up to you. But you can get what you're looking for from the S197. Of course you can't change the interior, but ride/handling wise no problem.
My car is primary track and fun, but they are fine on the street.
I am on stock sways with poly bushings and it is neutral. My tires sizing is square so YMMV.
With few exceptions there isn’t a bad coil out there. Pick one from the go racing guys. Rather than the get slammed guys.
There are are a million opinions as to how to handle the rear bump stops after a drop. You can read yourself to death and make your own choice.
Like I said, my S197 is very lightly modded, but it takes a pretty hot and well.driven car to run and hide.
3/21/15 08:51 AM
PSUpony
1/14/15 08:14 PM
2012GT
3/25/14 11:51 PM
