Changing wheels, wheel stuck
This is the first time this has ever happened to me. I was changing my wheels to my winter tires today and I cannot get the front driver's side wheel off. I removed the nuts and the wheel is like stuck to the hub, assuming from all the dirt and corrosion that have built up? I have SVE wheels on and was switching back to my stock Brembos which have Blizzaks mounted to it.
I tried getting under it a bit to kick it loose, but there is not a lot of room even jacked up and I was afraid the car might drop on me. I guess my only option is to take it to a shop and hopefully they can get it off. We are suppose to get our first snowfall tomorrow, so I'm driving with 3 Blizzaks and 1 Summer tire on, lol. Has this happened to any of you guys before?
Received 1,494 Likes
You just have to persuade it off of there somehow. If you can get a hammer on the back of the wheel, that will probably break it free. (use a wood block to prevent damage to the wheel). I have seen suggestions that if you loosen up the lugs a little (just maybe 1/4-1/2 turn) then drive the car a few feet and hit the brakes, that may break it loose. Or if all else fails, yeah you can take it to a shop to get it off.
Before reinstalling, clean off the corrosion and apply some grease or anti-seize to the hub so it won't happen again.
Thanks, will try to see if I can knock it loose with a hammer. I've driven this car through three dirty and salty winters with no problems, this is the first time this has happened.
You shouldn't need a hammer-just kick the outer edge of the tire with your heel all the way around to try and loosen it. That should work fine.
On my Mustang I've only ever had to kick around the sidewall a few times to get it loose, but on my truck the wheels were really stuck on there so I had to hit it with combination of a deadblow hammer (the plastic ones filled with steel shot) and kick it, both from the backside of the wheel.
Try hitting it with your purse
