Creaking Noise When Braking
Old 11/14/17, 05:39 PM
Nikita's Avatar
I have searched the internet for the past year for a solution to my problem with no avail. In my research, I have discovered that many people are having the same issue as me but nobody has ever posted a solution that worked. I am about ready to pull my hair out so I have decided to hit up the forums myself and ask for advice.
Here's my problem. I have a 2014 Mustang V6 Premium. No performance package. I am hearing a creaking noise like a old spring mattress or old creaking plastic office chair in the front passenger side of the vehicle. The noise is coming from the lower front passenger footwell. The noise occurs when I apply the brake, and begins when the nose of the car dips, all the way through when the nose rises again, and then it stops. Here's the facts:
1) Creaking noise during braking
2) Does NOT creak when braking stationary
3) Does NOT creak when pushing down on suspension
4) Does NOT creak when pushing the car forwards and backwards
5) It's NOT the calipers (I've replaced all 4 calipers)
6) It's NOT the brake pads (I've replaced all 4 brake pads)
7) It's NOT the front sway bar bushings (I've replaced them with polyurethane)
8) I've sprayed silicone lubricant on all moving parts/bushings/rubber/etc.
9) Both front lower control arms were replaced under warranty/TSB due to noise going over bumps
10) While the car was under warranty I took it to Ford and they claimed they couldn't hear it (It's loud)
11) I have installed everything correctly and have applied the proper grease and brake silencer
12) Creaking is louder in cold weather but still noticeable in warm weather
13) When slamming on the brake there is no creaking (possible noise could be getting drowned out)
14) When I brake so that the car nose doesn't dip, there is no creaking noise
15) Creaking won't begin until under about 40mph
16) Factory rotors were turned before doing brake job (still in great condition)
17) I have bled the brakes
I believe this is everything. Please HELP ME!
Old 11/14/17, 06:35 PM
Cavero's Avatar
That definitely sounds like everything. Any difference w/ the car cold vs warmed up?
Old 11/14/17, 09:31 PM
PonyMuscletang13's Avatar
This may sound silly but won’t hurt. If you open up the hood there are some screws bolted on top to hold the front fenders to body. Check any are loose.
Old 11/15/17, 01:49 AM
Nikita's Avatar
There is no difference whether its a cold start/warmed up. Those screws were tight, not loose. I was able to give each one a 360 turn with the wrench. Will update to see if that does anything when I drive it tomorrow.
Old 11/16/17, 06:34 AM
JonsMustang's Avatar
Sounds like my car. 13 GT haha...
Video the sound and upload it here.
Old 11/18/17, 05:46 PM
kylerohde's Avatar
Have you gone to the dealer and had a service d manager ride with you? That’s how I got them to finally diagnose the noise I had that turned out to be a bent rear axle shaft.
