2014 GT failing o2 inspection test
So I've been having trouble passing emissions test for the past 2 months and I'm that late on my registration.
I changed the battery and positive battery cable about 4 months ago. I put about 2k miles on the new battery and then ended up failing inspection. The o2 sensors say "not ready." So I did a drive cycle like the inspector told me to and brought it back a couple weeks later. Failed again.
At that point I figured it might be something to do with my tune. I'm running a 93 octane bama tune. I passed inspection on this same tune a year ago and haven't changed anything since then, and I know the o2 sensors are on. But just to try, I loaded a new completely different tune on my sct tuner and made sure to set the o2 sensors to on. I can't set the car back to stock because I have a 101 mm cold air intake and don't have the stock one, so I can't run a stock tune. But anyways, I did another drive cycle and inspected again today, and failed again on this completely different tune. My tuner is not listing any codes or any problems. My check engine light is not on.
At this point I have no idea what to do. Could my o2 sensors just be broken and need to be replaced? Maybe unplugged? Is it something with the PCM? What should I do?
One thing I've done is purchase a Bluetooth OBD dongle and the Torque app. You can scan to see if you've managed to get the sensors ready without going in for emissions each time.
