Clutch Master Cylinder eyelet broke
Clutch Master Cylinder eyelet broke. It's the eyelet looking piece that balloon 2 retains onto the pedal:
Anybody have a solution?
Edit:
Update. Found this on Ebay and ordered. Hopefully, all goes well!
http://www.ebay.com/itm/322568809400
Edit:
Yeah, well, I thought about that, and then figured if this thing broke, how much longer is the plastic master cylinder going to last? And then I had the whole thing replaced. Just my $.02 on it.
Kinda scary when it happens, right? :I
Freaked me out alright! I was shifting into 2nd and between gears when it happened and worse, I was on a country road blind hill (no shoulders) and had to pull off so only half my car was on the road. I have the hood up, flashers going for people coming behind me, but it'd take some guy racing down the middle of the road from the other side to cream me. I managed to line up the cylinder piston to the clutch pedal and get it into first and get it rolling, and limped home in 1st the whole way. First thing I did when I got home was started sleuthing what happened.
I thought about changing the whole cylinder, but a $40 fix versus a $80 part plus labor at my local shop. =/
...and so the idea is you'd replace the whole thing, 'cause shouldn't have been able to buy the plastic bit without the whole thing, so... New part, never gonna leak and screw things up...
...but it's just a thought.
I'm thinking that along with cost, this thing would break first... meaning that it won't (shouldn't?) allow you to keep running with the old master cylinder... that'll leak... into the car... or somewhere else... and mess up things...
FWIW, 115K miles on the 'Stang.
I just read about this, and mine broke tonight. Off to ebay for the aluminum replacement!
UPDATE 9/4/2017 - Got the part from Backwoods Diesel Saturday, and it takes about 15 minutes to install. Perfect fit, works great. A terrific solution compared to buying a complete assembly with the same plastic bushing again.
wanted33 (10/3/17)
