Alignment advice...
Alignment advice...
Had my alignment done after my suspension install and I think I should pick up a pair of cc plates. Running -1.5 camber where I mostly drive highway daily, spring/summer only and stored for winter. Installed Steeda Sport springs, Koni orange dampers with GT500 strut mounts. Prefer not to eat up my tires based on how I use my mustang. What do you guys think?
I think you'll be fine at -1.5 camber. I run -2.0 for the track (but also daily for ~8000 miles between March and November) and I don't see any extra wear on the inside of the tire. I'm sure over 40k miles there might be some, but just stay on top of your rotations and you should be fine
plus all the extra front end grip eliminates any understeer you may have experienced on the street before. And taking clover ramps at ludacris sppeds at 1g is fun too!
I agree with 5.Monster. The negative camber shouldn't introduce much wear if you rotate regularly. Uneven wear on the outside edges is usually do to issues with toe in, not camber. Also, which way did you install the GT500 mounts? You can flip them around for more/less camber depending on which way they are mounted. You may be able to flip them around and reduce the negative camber without buying another set of upper mounts.
As far as rotating, can't because I have the Boss Laguna Secs wheels so it's a staggard setup. Here are a few pics of my setup...
Sorry, I don't remember exactly where I read it but I think it was in someone's install thread. They said to install the pivot bracket on the lower holes. The instructions aren't the greatest. I read several threads and modified the Whiteline PDF so it had all correct info when I did the install, like the torque specs.
