My OD off light is blinking constantly
Old 5/21/12, 05:27 PM
Started doing it today any ideas why it might be doing that. It also seems to clunk into all gears now. Everything seems tight u joint wise.
Old 5/21/12, 09:04 PM
retfr8flyr's Avatar
The OD light blinking is a code for transmission problems. Take the car to a Ford dealer that you trust and they can read the codes. It could be just a solenoid problem or it may be something worse but you need to get it checked out.
Earl
Old 5/22/12, 10:47 AM
yea I have been reading it could be any thing from a solinoid to replacing the trans. Crap
Old 5/23/12, 05:35 PM
Made an apt for tomorrow morning for a diagnostic test 65 bucks. Pray for me
Bonnie (3/3/23)
Old 5/24/12, 04:17 PM
sooooo I picked the car up from service and the guy tells me two fault codes come up
pp798 Pressure Control Solenoid "C" Electrical
po791 Intermediate Shaft Speed Sensor "A" Circuit
can't find anything on the net about these codes. Please help lol He tells me it has an internal problem. Daaaaaaaa I could have told him that lol
Old 5/24/12, 10:44 PM
antdog's Avatar
pp798 pc solenoid c eletrical
po791 pc solenoid control circuit high
http://www.allfordmustangs.com/forum...odes-dtcs.html
Old 5/25/12, 07:35 AM
Thanks Ant! I'm wondering if they will have to pull the trans to get this fixed.
Old 5/25/12, 03:04 PM
antdog's Avatar
Considering they get paid by the hour, probably.
Old 5/25/12, 07:25 PM
Stoenr's Avatar
Shoulda got a stick
Old 5/26/12, 05:25 AM
Originally Posted by Stoenr
Shoulda got a stick
so I could hit you with it??
VGMStudios (6/14/19)
Old 5/26/12, 10:07 AM
Stoenr's Avatar
Haha, good one
Old 5/31/12, 11:15 AM
Replaced the solenoid pack 420 bucks for the parts. Total for the whole job 561.00 bucks included filter and fluid. The guy at the trans shop said it was a common problem with the fords. Pretty easy fix, drop the trans pan remove the filter and you will see the sol pack. Remove a few bore bolts remove bad part and reinstall new parts.
Shifts smooth as butter now.
Bonnie (3/3/23)
Old 5/31/12, 11:31 AM
Old 5/31/12, 08:26 PM
antdog's Avatar
Happy for you and your wallet!
Old 6/6/12, 07:39 PM
naezwoot's Avatar
Just be easy, the car will find its way round the hill when it gets there. hahah
Old 6/13/19, 02:18 AM
Tommymac's Avatar
The solenoid pack, does that pack contain all of the different solenoids that have have to do with the transmission? What trans shop did you take it to?
Old 6/13/19, 02:23 AM
Tommymac's Avatar
Old 6/13/19, 07:22 AM
I am not sure. I believe it is one solenoid. I took it to a well known transmission shop. I forget the name of he place. It was in Orland Park IL
Old 11/9/19, 06:17 PM
Robert Wells's Avatar
O/D lights flashing on when it get warm and sometimes when I turn off my mustang in restart it stays off 20min. In comes back on help
Old 11/15/19, 10:52 PM
VistaBlue09's Avatar
You should take it to a reputable transmission shop. You might consider one that’s an ATRA member. The blinking O/D light is like a check engine light for the transmission. You need to have them pull the codes and see what that shows.
RCooke08GT
2/19/17 03:03 AM
10/2/15 01:00 PM
boz
10/1/15 04:47 PM
mmb0329
10/1/15 10:59 AM
Fedupdave42169
9/30/15 08:45 PM
Quick Reply: My OD off light is blinking constantly
