How To Section By TMS Member 1 Old Racer How To Threads & Youtube Vids!
diff cooler build
Old Mar 27, 2021 | 10:08 PM
1 old racer's Avatar
Royal Crimson GT PP1 Member
diff cooler build
Old Mar 28, 2021 | 08:25 AM
Cavero's Avatar
Very cool (no pun intended) and good video. For the clearance on the sway bar, wonder if you could get some more 90 deg fittings to be able tuck the lines closer to the chassis. But I guess sharp bends don't help for flow and you've got to leave some slack for the suspension movement.
Just curious, saw that scooter battery at the beginning, are you going to use that to power the fan between runs? Or just use the car battery? When you're running it, do you leave the trunk open to let the heat escape?
Old Mar 28, 2021 | 10:29 AM
it will be hooked up to the fuse panel and run off the car's power system. However you have given me a great idea. For pit cooling. I will need two batteries because of the amount of amps needed. but I can pick up two for under $50 bucks on ebay and they will run the pump and fan for about 30 mins with no problem and that with a four year old battery. Great idea, thanks
Old Mar 28, 2021 | 11:42 AM
Old Apr 3, 2021 | 10:42 PM
Decided to route wire to the center compartment and the power supply and ground from the fuse panel located on the right kick panel. Routing the wire to the center storage compartment was the hardest part of this complete build. Mounted the twin switches to a project box that fit perfect inside the compartment.
Old Apr 5, 2021 | 08:50 PM
shaneyusa's Avatar
Very nice
Old Apr 11, 2021 | 09:32 PM
The final piece was constructed and put in place. I faded a support table to go around the cooler/pimp and lines that will sit flush with the underside of the cover. now I can tthrow a spare in the trunk with out worrying about breaking the cover.
Old Apr 12, 2021 | 01:11 PM
houtex's Avatar
Very nice!
I might be a bit concerned with the legs maybe rubbing the tub down there and possibly causing a paint rub through and subsequent rusting thereto, so... might there be some sort of decent rubber matting under the legs I don't see? Or maybe I need to be less worried as not daily and all that...
I like it though! Well done!
Old Apr 12, 2021 | 05:32 PM
Originally Posted by houtex
Very nice!
thanks and great idea. I have some indoor/outdoor carpet left over from a project that i have not thrown away yet. I am going to cut thin strips and contact cement them at the bottom of each upright.
Old Apr 24, 2021 | 12:19 PM
Here is a update to my diff cooler build. The most asked question and comment is reguarding why I put the pump before the cooler because it is poor practice. Answer is they are correct, to a point. If the location of the pump is located close any extra heat source that will not allow any airflow around the pump. However, due to the fact of the pump and coolers location, (inside the spare tire well), excessive heat soak was not a issue. But this really bother some people. So just to show how easy it was and is to hook it up correctly I did. Now all is well and to be honest it should have been done this way the first time but I was one AN fitting short. So here it is all corrected. I also improved the overall install by adding some 3/32 thick rubber sheet to any area that might touch the tub and under the pump for a little more vib damping.
Old Jul 1, 2021 | 03:23 PM
oops forgot to share the electrical hook up video to this bld. thanks for watching.
Kinyodas
Motorsports
Feb 24, 2012 07:23 AM
ulev1st
2012-2013 BOSS 302
14
May 30, 2011 08:07 AM
Route 66
Jan 25, 2006 10:32 PM
dtoups
Feb 2, 2005 02:09 PM
TURBO 05
Jan 20, 2005 03:36 PM
