A/C Blend door possible fix (Worth a try).
(Re-syncing actuators) If you are having A/C air coming out warm on one vent & cold on other vents / or blend door issues, this simple fix is worth a try before delving into blend door motor replacement etc. Have done this & it worked for mine.
While car is parked. Start car & turn on A/C (Cold) WITH FAN SPEED ON MAX setting, run for 5 mins. Now turn to the highest (MAX) heat setting WITH FAN STILL ON MAX & run for another 5 mins. Return fan speed to normal setting & temp all the way back down. Now check blend door to see if fix has worked. |
Yep That is a Good One!
Moved You To Repair & Service Help For Easier Search! Ran Across A Similar But a Little Different Procedure While Researching Some Other HVAC Issues The Other Day on an 05-09 Kc |
:nice:
Thank you for sharing your solution... Hopefully, this method will save other owners $$$ from having to take their cars back to the dealership for servicing... :nice:
| All times are GMT -6. The time now is 04:45 AM. |
