1971-1973 Mustang Member Tech & Restoration Discussion
Side stripe changes info needed - 1973 Mach 1 Mustang
Old May 8, 2005 | 10:05 AM
leener6357's Avatar
I am confused about 1973 Mach 1 stripes. Almost everything I read says the side stirpes changed in 1973. But I have several books that show the higher full length stripe on a '73 as well. Then I surf the net and see both the lower 3/4 length stripe on some and the higher longer on others. The rear stripe change from 72 to 73 seems to be consistent, but not the side. Can someone clear this up? Thanks.
Old May 9, 2005 | 06:03 AM
fun69mach1's Avatar
I believe that the correct striping for the '73 is the lower stripe and it only runs to the front of the rear wheel(three-quarter length).
Old May 22, 2005 | 04:10 PM
dingo's Avatar
Here's what the 73's stripes look from the side and back. Completely different all around than the 71-2. 73 Mach 1
A lot of people you will find put the full length narrow stripes from 71-2s on the 73 Mach1s just for the looks.
runfox
05-09 Exterior Modifications
Dec 31, 2005 03:10 PM
Surge13
Feb 28, 2005 06:40 PM
1hellraiser
Jan 16, 2005 10:45 PM
Foxbat
36
Jan 2, 2005 03:19 PM
