| Mystang68 |
Feb 29, 2012 07:24 PM |
71 C4 tramsmission problem
I have a 68 Coupe with a 71 351C paired with a 71 C4 transmission. Recently I changed out the transmission filter and gasket as part of regular maintenance. The fluid was still pinkish/purple as it should be and there wasn't any metal flake in the pan. All looked good. When I put everything back together, the transmission started making a grinding noise when putting it on park. It will HO through all of the gears perfectly, but grind as you put it back in park.
Anyone have any ideas on what the problem is?
