Sponsored by:
Sponsored by:
Track Mode
Old Jun 20, 2015 | 01:43 PM
Mustm26's Avatar
Track Mode
I put my GT premium in Track Mode today for the first time out in the 'country' on a straight farm mode with traction control off. Not knowing what to expect when I punched it I was surprised how fast it got up to 90+ before I ran out of road safe from oncoming smokies.
Old Jun 20, 2015 | 03:12 PM
pminri's Avatar
Track Mode
It really does wake up the car. The throttle response is much better. Do you have stock mufflers? After market ones sound awesome with the track tune..
Old Jun 20, 2015 | 03:18 PM
Mustm26's Avatar
My mufflers are stock. They are loud enough for me at my age.
Old Jun 22, 2015 | 04:47 AM
pminri's Avatar
Track Mode
The o let other thing I noticed when using the track key is if you buy no name gas ( even if it's still 91+ octane which is the min with the track key) it has a very pronounced sulfur odor. I was buying it at a wholesale club when I noticed it but when I switched to Shell V-power it went away. Not sure what the deal is there but I hate sulfur odor.
Enjoy the track key!!
Old Jun 22, 2015 | 07:51 AM
Mustm26's Avatar
Just before my run I did fill up with Shell V Power Nitro. Most likely that added to the increase in performance. I always use name brand but recently switched from BP premium with so called really good additives to Shell. Have not noticed any sulfur odor yet with either brand.
Old Jun 22, 2015 | 08:46 AM
Jazzman442's Avatar
My Family use to be in the Gas business for many years. Only and I repeat only Use Tier one Gas in these cars. The Track key and any hipo mods especially. There is so much more to gas than just octane.
Old Jun 22, 2015 | 12:58 PM
pminri's Avatar
Track Mode
I am quickly learning This. Thx for the tip.
Old Jun 22, 2015 | 01:36 PM
Jazzman442's Avatar
When I use my track key the car seems louder and really responsive. The acceleration is night and day from the Factory key. I just can not believe how quick these cars are.
Old Oct 31, 2015 | 09:17 AM
dblhelx's Avatar
I don't think there's a track KEY for the 2015 yet. These 15/16 GT models have a switch on the dash that allows you to toggle between different driving modes. There are rumors that Ford is developing a factory Tune for the S550.
Old Nov 3, 2015 | 07:54 AM
blipszyc's Avatar
If there is a track key, my dealer didn't know about it for the 15/16s. He basically said its all built in now.
Old Nov 4, 2015 | 02:50 PM
AlphaM1's Avatar
Try holing up/down the trac off switch/button for twenty seconds and then try to floor it. Be warned!!!! There is no traction at all and tired will break loose and you could loose control
Old Nov 4, 2015 | 06:46 PM
5.M0NSTER's Avatar
I drove a 2015 GT (non-PP to be fair), and tried all the modes, and even line lock. I had the car for a day. Line lock was fun, glad it wasn't my tires, haha.
To be honest even in track mode it felt a lot slower than my 14 GT Track Pack. I think the less aggressive rear end is a large part of why that is., plus the 15s are heavier.
Old Nov 4, 2015 | 08:08 PM
bob's Avatar
bob
Tru'dat, hell Top Tier gas in any car.
http://www.toptiergas.com/
http://www.toptiergas.com/retailers/
Old Nov 4, 2015 | 08:11 PM
bob's Avatar
bob
Yeah weight mostly, I'm not sure about all the gear ratios (3.31 and 3.55????) but I'm not impressed with the 3.73 gear set in my PP car. 1st and 2nd come up way to quickly when your on the loud pedal.
Old Nov 4, 2015 | 09:43 PM
Jazzman442's Avatar
The weight and the power you loose in an IRS. All the Mags have documented this. It is the reason I have the 14. But the GT350 is looking good.
Old Nov 5, 2015 | 05:57 AM
5.M0NSTER's Avatar
I hear you, my car has 3.73s as well. This gear set is made for shredding tires. I love it on the street. Acceleration particularly is 2nd is phenomenal, but it's a challenge to keep it from bouncing off the rev limiter. I love doing 4000 rpm in 2nd, and rolling onto the throttle. Later suckers! My left foot and right arm get a workout rolling through the gears a lot.
But my car is also a weekend track warrior, and there the 3.73s are deffinitely too short. I've found myseld running out of gear with a few hundred yards left to the brake zone. Do i shift, or do I just ride it? I think 3.55 would be a better choice for Track Pack and PP cars. Unless you have a 8200rpm redline.
Old Nov 5, 2015 | 08:13 AM
tom281's Avatar
PP cars have to shift into 3rd just to hit 60mph on the timer unless you raise the limiter. I almost wish my car had 3.55s in it but with 3.73s and the blower it is a ton o fun.
Old Feb 15, 2016 | 05:31 PM
ohlang's Avatar
Assuming you all have manual transmissions, I'm not sure how Sport+ and Track have any real affect for you guys, but in automatic transmissions, Track mode is a beast. The auto in track mode even with 3.55 gears will get the jump and maintain the lead against a manual with 3.73 gears 19/20 times. For Auto in track mode, there's no throttle lag when you perform WOT's at rolling speeds because of the reduced traction controls.
Old Feb 15, 2016 | 06:42 PM
AlphaM1's Avatar
So did you take trac control off by holding it down for 30secondd? Or just by turning it off the regular way? If you didn't hold it down for 30 seconds, try that with WOT, but be warned you will not get any traction and **** can hit the fan quick!!!!!
Old Feb 15, 2016 | 07:55 PM
ohlang's Avatar
Holding it down until Advancetrac Off indicator appears removes both traction and stability. On Base GT's, double tapping the traction button, leaves stability and places traction in a reduced state called Advancetrac Sport Mode. On GT Premiums, it's only available in Track mode. The only time I've ever seen the need to remove everything was when doing donuts.
