Sound tube question
I have a 2017 5.0 GT and hear talk about removing the sound tube. What is the purpose of the sound tube and why is everyone removing it. I did a search with no results. thanks.
The sound tube adds a small amount of engine noise to the passenger cabin. Many delete it just for a cleaner looking enginebay.
Originally Posted by SpectreH
(Post 7014881)
Thanks for the info, guess I'll leave it in place for now.
Mine came off a week after purchase. The droning and increased DBs in the cabin gave me headaches!
I kept mine in, I like engine noises. I have a Steeda CAI now and I still kept it the sound tube. I did not notice an increase in cabin noise with the CAI.
I kept mine in. I just want the engine bay to look factory. I dont think it sounds bad. I put on GT 500 AB and now I dont hear anything but them.
New today, how do you remove the tubes, and is it difficult to do, I'm not much of a mechanic. Looking to get a 2018 GT convertible and then put in the cold air set up, I like the sound that was in both my 2013 and 2014.
Originally Posted by EF1
(Post 7014925)
:agree: Also, if you add a cold air intake it may increase the amount of sound transferred inside due to the additional air flow. I removed mine after installing the Steeda cold air intake as the increased noise became annoying.
Originally Posted by Thomas Wyman
(Post 7016197)
The next hardest part is installing a plug in the hole left in the firewall. Its just as hard to reach as the nut was. I had my wife do it. Was easy with her smaller hands and thinner arms. If true that its easier to remove the nut from below the car, probably the same for the plug. The intake end of the tube couldn't be easier. Regardless of how you remove the tube, you'll need something to plug the holes where it attached to the intake and firewall. There are kits made or you can do an internet search for Home Depot/Lowes items to get the job done. |
Originally Posted by tourer
(Post 7016233)
Don't forget to plug the hole after as you will have an oil smell when the engines fully warmed up.
+1 for leaving it alone
I'm for removing it. At high rpm, I would hear weird noises and get scared something was wrong with my engine. There were noises I've never heard and I've driven, owned, and worked on a lot of cars. I found out after I removed the sound tube that it was piping in the noise that was freaking me out. All the sound I hear now is from my engine and exhausts.
Hey all, I just "deleted" mine this past weekend. I bought a '16 GT that has a Livernois CAI. With the cat backs and the intake, the noise in the cabin was annoying, especially when the frequencies of both clashed. Instead of fully removing the tube, I disconnected the end that connects to the intake tube, installed a rubber cap that covered the intake side, then put the hose back on. I did the same on the other end of that same tube (the 2 foot long tube), so I have both ends capped, but the hose is still on. It killed the sound and still looks factory.
http://i.ebayimg.com/images/i/251172...-1/s-l1000.jpg |
I installed an axle back exhaust and thought I would remove the sound tube after all. The experience was no different for me than the others who did this mod before me. It was a *****! Anyone who states it was a 20 minute start to finish job is not being 100% truthful. But its done and the part removed is in tact and can be reinstalled if needed. By the way I didn't notice a difference in cabin noise but the engine bay looks cleaner.
I removed mine a couple of years ago, but i don't remember it taking very long.
[QUOTE=HoosierDaddy;7016423]2018 could be different but for the 2015-2017 the firewall end can be difficult to remove if you like to do it by the book. There is a 10mm nut on a zillion thread stud that can be hard to get to..
I agree, but if you take your time you can remove the entire piece without destroying the tube. Buy small end caps at Lowes or Home depot for $.60 and plug the hole in the firewall and intake tube - Not a big deal and you are good to go. The tube is a worthless expense and doesn't do much. Just make sure the cap to the intake tube is tight A small (black) zip tie around the cap is good insurance. |
Originally Posted by ustabawannab
(Post 7016737)
Forgive the resurrection of this Sound Tube thread. It looks as if it was thoroughly beaten a year or mor ago. but I just joined the ranks of Enlightened Eighteen owners, and have encountered a problem or two.
On a previous 5.0 Mustang I put a plug in the sound tube, screwed in a little brass screw, and called it done in about fifteen minutes. Today I dug out some plugs, and opened the hood of the Performance Package expecting to do the same job. O, my. There is so much shielding enclosing everything, I can't even see the Sound Tube, let alone disconnect and plug it. Is there a secret technique for moving all those covers aside? They all seem to be strongly connected to the body or engine, no slack or wiggle room that I can find. While I'm at it: the battery has disappeared under some kind of rubber thing that doesn't want to move, either. There are some fasteners that look as if they might allow movement if released, but my experience with such things is that they might come apart easily, but require skills or a few duplicates to button them up. More secrets? I've been a fairly competent parts installer on my previous Mustangs, but this one has me stymied. I'll appreciate any guidance, teaching, and sympathy. |
Best advice go to CJ Pony Parts and check out their how to videos. Bill Tumas shows you what and how to remove almost everything. My sound tube on my 18 was a PITA to get to and the 10mm bolt on the firewall was stripped from the factory(Surprise, Surprise) In any event I got to the bolt from underneath the car and it came off using a deep socket and universal in 1/4 drive. The sound tube on my 2011 and my 2015 were a lot easier to remove for some reason.
