Sponsored by:
Sponsored by:
Old-Style Performance Mod
Old Jun 6, 2016 | 07:09 AM
PTParks's Avatar
Is there any advantage on running a colder thermostat on the newest generation of Mustang GT's? In the past, the practice was to install a 160 degree thermostat to keep the car within a cooler operating temperature which also added some additional fuel added to the mix, both of which kept the knock sensors from pulling timing out of the car due to pre-ignition.
Old Jun 12, 2016 | 11:14 AM
scott_0's Avatar
you cant just throw it in and call it a day, your vehicle needs to be tuned to take advantage of the lower operating temps
Old Jun 13, 2016 | 06:19 AM
1 Alibi 2's Avatar
Run 170* t-stats in both cars.
In order to get the max benefit, per the mfg., the Hi/low fan settings need to be reset in the tune.
..................( they supply the settings )
Old Jun 28, 2016 | 08:43 PM
Roadk9's Avatar
the Racerboy reply is yes. You can potentially make more power with a cooler engine. The DD reply don't waste your time and money.
creddick
Mar 31, 2016 07:51 PM
Jaxx68
Mar 28, 2016 08:43 PM
amusmani
Mar 13, 2016 07:16 AM
