Line lock not showing up
i have a 2015 Automatic Mustang GT premium convertible. When I go to track apps, line Lock and launch control are not showing up. Any suggestions? |
Lots of view, zero help. |
sorry
Have you tried using Forscan and doing the settings yourself? Reasonably straightforward. Details on the Forscan site.
Just curious, but is launch control part of the automatic set up? I have a 2018 and use launch control but it is stick. Don't see how you can do that without a clutch.
Automatic equipped Mustangs do not have launch control but sorry no idea why the line lock feature is not showing in the Track Apps. Take a look at the owners manual??
I was worried about that failure to appear by the Line Lock, as well, but somehow when I needed it, there it was. Something to do with the ignition being on, transmission in gear, something like that.
User Manual: Initiating Line Lock The initiation stage verifies that the vehicle is ready for line lock function, and confirms driver intent. Follow the prompts in the information display to initiate line lock. The following conditions must be met to initialize line lock: • The vehicle is on a level surface. • The engine is running. • The vehicle is traveling less than 25 mph (40 km/h). • Selectable drive mode is not in wet mode (if equipped). • There are no electronic stability control faults. If you want to cancel line lock once it is initialized, press the left information display control. Once initiated, line lock is prepared for activation and remains initiated up to 25 mph (40 km/h). If vehicle speed exceeds 25 mph (40 km/h), line lock automatically cancels. Engaging Line Lock Follow the prompts in the information display to engage line lock after it is initialized. To engage, firmly apply the brakes. Then press the OK button. Once engaged, release the brake pedal. The front brakes remain applied and the rear brakes release. At this point, the engagement timer is initiated and shown on the driver information display. The following conditions must be met to engage line lock: • The vehicle is on a level surface. • The engine is running. • The vehicle is stopped. • The parking brake is not applied. • The driver door is closed. • The transmission is in a forward gear. • Selectable drive mode is not in wet mode (if equipped). • There are no electronic stability control faults. • The steering wheel must be in the straight ahead position. Releasing Line Lock While line lock is engaged, you can exit (release) the feature using the OK button. When you press the OK button, line lock releases immediately and normal vehicle function resumes. When line lock engages, a countdown timer shows the remaining time before line lock is released automatically. If you exceed the time limit, or another vehicle condition requires line lock to release, the system safely disengages and normal vehicle function resumes. Note: If you apply the brake pedal while line lock is engaged, line lock automatically cancels and normal brake function resumes. |
So it does work on car with Auto? That sounds good if so.
Originally Posted by Jeff Davis
(Post 7039730)
Question
(Post 7039723)
Originally Posted by Robert Jeschke
(Post 7070487)
I have the same problem with my Mustang, Do you solve the problem with you Mustang? What was wrong?
Hopefully Someone Else Has Solved this Issue and Will Post! Have you tried the Old Battery Disconnect So Everything Can Reboot! Can't Hurt. Give it Twenty Minutes! Happy Trails! KC |
I’m back
No, I never was able to fix this problem!
