-   GT (https://themustangsource.com/forums/f850/)
-   -   Check engine light came on (https://themustangsource.com/forums/f850/check-engine-light-came-549369/)
Garys2015gt Aug 9, 2022 07:57 PM
This morning I was driving and my tach flashed red .then I noticed my check engine light came on . Any ideas ? Car seems to run great .
Glenn Aug 10, 2022 06:15 AM
did you hit redline when the tach light up?
Garys2015gt Aug 10, 2022 08:37 AM
Yes it appears I hit redline
yes it appears I hit redline
Bert Aug 10, 2022 08:42 AM
I have seen some other posts with similar situation; apparently when you hit the rev limiter, it cuts ignition which causes a temporary misfire, and the computer sees that as a problem and triggers the Check Engine Light (CEL) .... I think it will go away by itself, if it does not go away, you might need to reboot the system by disconnecting the battery for a while
MarvinN888 Sep 20, 2022 01:22 AM
If uncomfortable using the machine my experience is that many Auto Stores, Wallwork, Auto Zone etc will read the codes for free. The shop I use never charges to read a trouble code. That is my experience.
