Wheels for maybe winter ... GT size
Is there a favored de-facto wheel inventory? Pictures w/size/year?
Going by looks and net picture browsing alone, this set is on marketplace for $500, and look to be GT size. Currently there are 19x9 on the HPP, the GT spec from a Ford PDF has GT size 18x8 - which is a minus one size, but a little bit thinner and taller is good for winter. https://cimg7.ibsrv.net/gimg/themust...3db9b983ee.png Thanks! Only need the wheels ... |
generally any OEM wheel from the same generation (S550) should fit; unless you have the big brakes which I believe you do not
I would look for an 8" wide wheel, because I think that is the narrowest that they come, and narrow is good for snow tires $500 for a set of four is a good deal, would be even better if they already had snow tires on them (I lucked out and got a set of four used wheels with snow tires for $400, but that is a rare deal) I would look on my local Craig's List (usually the best deals) or E-Bay |
