fitment question
Hi guys I am trying to lower my ecoobost 2018 fastback to give it more aggressive look and I wan to make sure that fitment will look nice (no rubbing etc.).
This is set up I was advised by AM. Please let me know what do you think - RTR Tech 7 852GB 19x9.5 (same size front and back) - PILOT SPORT A/S 3+ - SIZE: 275/40ZR19 - Eibach Sportline Lowering Springs (drop 1.5 front 1.3 back) https://www.americanmuscle.com/eibac...-ecoboost.html I see this guy is running on 20x10 wheels + 275/35 tires, if my math is not wrong high should be same as 19x9.5 and 275/30 tires right ? https://www.fitmentindustries.com/wh...wering-springs Also this dude has 19x9.5 0.0mm Offset Wheels, 255/40R1 (mine are 275 /40 and same rim size). Springs he uses give .3'' less drop but it looks like he still has extra gap https://www.americanmuscle.com/ford-mustang-builds-profiles I already have wheels and tires and I am looking to purchase lowering springs. Should I consider Eibach Pro-Kit Performance instead ? Please let me know what you thing I would love to purchase them tomorrow. |
https://www.fitmentindustries.com/wh...wering-springs Also this dude has 19x9.5 0.0mm Offset Wheels, 255/40R1 (mine are 275 /40 and same rim size). Springs he uses give .3'' less drop but it looks like he still has extra gap https://www.americanmuscle.com/ford-...=606962&from=0 |
I am choosing the wheel and tire combo right now , so I did quite a big research on S550 tire fitment. Yes, 20x10 wheels + 275/35 is a perfect combo in terms of the looks https://specsandmods.com/bagged-ford...ct-stance.html but as far as I understand it's only good if you're bagged. If you use coilovers or simple lowering springs, recommend sticking with the 19s, at least, that's what I decided to do.
| All times are GMT -6. The time now is 09:36 AM. |
