2015 Mustang 2.3 Ecoboost First Ride
http://www.motortrend.com/roadtests/...#ixzz31n6JKLHo
Flat is a word that keeps coming up as the vehicle dynamics engineer at the helm of the 2015 Ford Mustang EcoBoost describes the results of his work fettling on this pending pony’s new suspenders. It corners flatter, it brakes a lot flatter, and it’s just a much more buttoned down car -- at least to hear him tell it. We’re in the sprawling parking lot outside the zMAX Dragway, across the street from Charlotte Motor Speedway threading the cones of a moderate-speed autocross course. Indeed, the view and sensations coming through the right chair give little cause for argument, and there’s plenty of good reason to expect such results based on the engineering design. This 2015 Mustang, the first that any journalists have gotten a ride in yet, is (almost) the nimblest package that will be offered -- 305-plus-horses from the 2.3-liter turbo and the performance package, but the six-speed paddle-shifted automatic is probably not the nimblest transmission. It’s a good choice for this exercise, though, as I can sense the way the shift schedule changes as my chauffeur toggles between the normal/sport/track modes better than I could have perceived clutch takeup and shifter feel without using my own limbs. 2015 Ford Mustang Ecoboost Rear Side View That track package eliminates all rubber from the front suspension links responsible for transmitting lateral forces from the tires to the chassis, replacing them with metal-to-metal ball joints. The suspension cradle to which they are attached is also un-isolated, all of which makes for more immediate reactions to steering inputs, and (theoretically) more feedback through the adjustable electric-assist steering (it’s supplied by the same folks who made the Boss 302’s rack). There’s more magic in the suspension geometry, made possible in part by the front struts’ double ball-joint lower attachment. This produces a “virtual” steering axis in the form of a cone that has the effect of moving the effective steering axis point further outboard, increasing road feel. Whether jinking through a lane-change or slalom event or accelerating through a broader sweeper, the 2015 Mustang EcoBoost’s body does seem to maintain a reasonably even keel -- a sensation backed up by watching laps from trackside. Overall grip from the 255/40R-19 Pirelli P Zero summer tires also felt appropriately sporting, and the limits we approached produced minimal squeal. 2015 Ford Mustang Ecoboost Front Side View Yellow 2015 Ford Mustang Ecoboost Turning 2015 Ford Mustang Ecoboost Front Side View To The Right 2015 Ford Mustang Ecoboost Door Open 2015 Ford Mustang Ecoboost Side View Door Open 2015 Ford Mustang Ecoboost Front Side View Yellow Door Open That double-ball-joint setup also frees up space for big brakes without increasing wheel offset. Performance package brakes here measure 13.9-inches in front, clamped by four-piston fixed calipers (just about like on the 2014 Mustang GT Track or Brembo Brake packages). Rears are 13.0-inch vented in the rear. The independent “integral-link” rear suspension permits way more anti-dive geometry than anyone’s live axle could, which is the biggest contributor to the flatter braking. Working together, the front and rear suspension resist dive, squat, and lift twice as well as before. One burning question that goes unanswered for yet another 2015 Mustang program is mass. The only clue we got was an admonition against counting on the I-4 weighing a whole lot less than the base aluminum V-6. It will, however, reach peak torque way lower in the rev range, meaning that even if it doesn’t produce much more than the 305 hp that the V-6 does, it should very easily outrun that car. It certainly seemed to move out every bit as smartly as a 2014 Mustang V-6, thanks in some part to the performance package’s 3.55:1 axle ratio. That axle is optional on the 2015 Mustang V-6 and 2015 Mustang EcoBoost I-4, with 3.15:1 the base axle on both (the 2014 V-6 made do with 2.73:1 or 3.31:1, the latter of which will also be offered on the 2015 I-4). Folks interested in optimizing their EcoBoost Mustangs for autocross circuits like this (and not CAFE optimization) might try fitting a 3.73:1 axle, which we’re told will be offered on the V-8, though it doesn’t show up on the spec sheets yet. In the “track” transmission mode, lower gears seemed to hold nicely while braking into the big sweeper, and the box’s reaction to paddle inputs seemed quite instantaneous. In that mode, a manual gear selection pretty much holds no matter what, resting on a smooth rev limiter if you insist. 2015 Ford Mustang Ecoboost Front Side View The engine note of the 2015 Mustang EcoBoost sounded pleasingly snarly -- which isn’t easy with a turbo muffling the exhaust -- though final sound tuning has yet to be completed. When it is, the sound reaching your ears will be a symphonic composition of genuine intake and exhaust frequencies enhanced by nice noises piped in through a sound pipe and objectionable ones erased via active noise cancelation. That’s about all we can tell you at this point, but rest assured the Chinese water-torture dribbled release of Pony-car info will continue right on through the promised full-on drive programs later this year. |
Well I guess this confirms that the Ecoboost performance pack can be had with the auto. Also, I like what I'm hearing about the paddle shifters and the quick shifting speed. I've always had stick shift and am hesitant to get rid of it, but the reality is that I do a lot more long road trips roads with only 1 or 2 lanes, thus I really want the adaptive cruise. I have it in the Explorer and LOVE it.
Glad to hear the ecoboost sounded pleasantly snarling....... Yawn
Sounds like a good performance package. I'm very anxious to test drive one of the new ones with a track package. Good to hear the first review!
Why no video??
You might as well buy a Honda than a 4 cylinder mustang. I don't care how much power it produces.
Originally Posted by yugoboss
(Post 6803501)
So when one considers the performance handling that is detailed (showing less concern for NVH), the increased low end torque, and the flat handling; I believe this will relegate the V6 to the 'Secretary Only' class who just wants a fun drive in a Mustang. Leaving the V8 for the V8 performance crowd like me, and the suped up Ecoboost for the nonV8 performance crowd. I'd love to run an Ecoboost through its paces on my favorite 2 lane twisty mountain roads. :nice: Of which Bullitt dominates. :grin: |
(Post 6803501)
Originally Posted by cdynaco
(Post 6803510)
While I understand that sentiment on the surface - and will not part with my V8 - I have also always loved a high revving DOHC 4V I4. Adding turbo is even juicier - and beyond what your Honda is offering at present. So when one considers the performance handling that is detailed (showing less concern for NVH), the increased low end torque, and the flat handling; I believe this will relegate the V6 to the 'Secretary Only' class who just wants a fun drive in a Mustang. Leaving the V8 for the V8 performance crowd like me, and the suped up Ecoboost for the nonV8 performance crowd. I'd love to run an Ecoboost through its paces on my favorite 2 lane twisty mountain roads. :nice: Of which Bullitt dominates. :grin:
(Post 6803521)
I'm sure you would, with that new fangled IerRS thingamuhjiggy :lol:
:grin: |
(Post 6803525)
Simply to hear the little 4 scream - cause other than that I won't know how to drive it. :panic: Just like I have that nerve in my butt for my wallet, my butt & brain & steering hands are hard wired to an SRA. :grin:
Autoblog also was there for a quick ride. There's a gallery too. :) The third to last photo in the gallery is a nice angle.
I hope I don't throw up the first time I hear one zing by with the fart pipe sounding like a Neon or Miata.
Originally Posted by Automatic 5.0
(Post 6803955)
Originally Posted by IndustryLeech
(Post 6803513)
This is a really sound statement, backed up by impeccable logic.
I love the V8 sound, even if the 4 and 6 cyl versions put out more power. in my opinion, the $5k extra for a 06 gt over a v6 was worth it for the sound alone :) |
(Post 6804455)
guess my logic is equally flawed- but it really is a SOUND statement to me too... I love the V8 sound, even if the 4 and 6 cyl versions put out more power. in my opinion, the $5k extra for a 06 gt over a v6 was worth it for the sound alone :) It boils down to personal preference but for me I miss the sound of my V8. What I have now doesnt cut it. Im worried how the prices are going yp but im hoping I can swing a GT Premium come late 2016. |
(Post 6803501)
http://upload.wikimedia.org/wikipedi...ustang_SVO.JPG |
Originally Posted by tom_vilsack
(Post 6804601)
Another first drive, errr, ride, from Autoblog:
Riding Notes
This is the same way the car mags did for the 2011 V6 and GT. Just saying....:)
