Fitting rouche air filter/intake on 2016 v6.
Hi folks. I'm new here on the forum. I have a 2016 v6 and am thinking of upgrading intake system to a Roush. Can anyone tell me what this entails. I'm pretty good mechanically. I see the systems for about $450. Is this worth doing. Does it involve having computer reset and will I get better performance and mpg ?
If the Roush intake includes an intake tube insert which reduces the MAF tube housing to OEM stock? No computer reset is required.. If your interested in the Roush intake system, I would recommend contacting the vendor/merchant you intend on purchasing the intake system from to verify it's fully compatible for your particular application.. Meanwhile, welcome aboard.
Received 1,578 Likes
If the kit is designed and made for your car, then installation is super simple; just follow the directions. However, I am not sure if Roush makes an intake for that car/engine; and the V8 intake is not going to work without a lot of modifications.
Also follow the instructions regarding a tune -- if they say it needs a tune, then it needs a tune; it is not optional. In the past Roush did offer intakes with a removable insert to make them compatible with the factory tune, or you could remove the insert for a little more performance but a "custom" tune is required.
Bottom line: look at the information that comes with the product and follow the instructions. If you could post a link to the one you are talking about, we could comment more specifically, based on what it says.
Bert (6/28/22)
yep, looks like that should work, and installation should be pretty easy .... I assume they include instructions with the kit, but even if they don't, you can probably figure it out by looking at it
the screen shot does not say if it requires a tune, so just make sure you pay attention to that part
Thanks for the advice.
I contacted the seller and they assured me it didn't need a retune if I used the reducer sleeve.
I've had the Mustang for 4 years now. I decided to hang on to it since it hasn't done many miles and I really love it. Anyway I'm looking to do a few things to it. I wasn't sure where to start so I'm thinking of the roush kit. I'd also like a slightly louder exhaust so I'm looking into that although I'm a bit confused about what to get. Hence I'm on this forum looking for advice.
