2016 Mustang "Clunk" noise
Hello, I have had my V6 automatic 2016 mustang for 2 months now (1800miles) and it recently started making a metallic "clunk" noise when being shifted from P to R (Almost like you're hitting 2 dumbbells or plates together at the gym). Even has done it going from Park to Drive. I have let it warm up, tried different things, but always makes the noise. I have been researching and others have taken it to the dealer and was told that its a normal sound they all make. Does this sound normal? Any idea what would cause it? I love the car but the sound is scary:confused: Thanks!
Might be the driveshaft ... and very well could be normal.
Doug |
mine does the same thing , and they say its normal
Okay that's what I've been hearing. Thanks!
My 2016 just started to do it. Do you have any vibrations in the car at about 60 mph and up?
Originally Posted by JohnnyMustang2
(Post 6977993)
Dealer replaced drive shaft twice and it still vibrates alot at 70-76mph. Can be felt at lower speeds also. Dealer was told by Ford to tell me its a characteristic of the new mustangs. Tires were check and found to be ok.
Same clunking noise issue i have on my 2016 v6 auto with 1200 miles. Have any of you gotten it fixed?
I attached a clip with the same clunking noise |
Originally Posted by jesus3467
(Post 6999310)
I attached a clip with the same clunking noise https://www.youtube.com/watch?v=qSucf3OBdwk that the car is thowing of the torque and causing the car to go into limp mode. (They are looking for anything aftermarket so they don't have to do the work) I called another dealership and they said that's the dumbest **** they've heard. So depending on what dealer you go to make sure to have the factory tires cuz ford asks them if there are any modifications. But as far as the clunk noise mine has been doin that forever and nothing has happened and people say it's normal. Sucks though : ( |
