Need help with rev per mile specs for goodyear eagle f1 supercar tires in 285/40/18
Looking for the actual rev per mile specs for Goodyear Eagle F1 Supercar tires in 285/40/18. According to Goodyear's website, they list the revs per mile specs at 775 on a measured 10" rim. However, when I checked Tire Size.com, they list the revs per mile specs at 748. At any rate, I just recently swapped my rear axle gears and I'm not really sure as to which is the correct rev per mile specs for my particular application, as my measured rim width is 9.5 inches. In the meantime, any help/feedback provided would be really appreciated.
Thanks. |
I would believe Goodyear for the rev per mile. Load your tune with 775, have a passenger with GPS on their cell phone. Go 60 mph on your Mustang and see what the gps on the cell phone is showing. Then you can make adjustments. :)
Tirerack.com agrees with Goodyear - 775.
Originally Posted by David Young
(Post 7034146)
Update! as of 8/18/18. David, here's the latest info. I loaded the tune at 775 as recommended by Goodyear, did a test run comparison with the speedo and from a friend's GPS. The speedo read 100 mph in 5th gear at 2000 RPM whereas the GPS read 65 mph. Needless to say, the speedo was way off by 35 mph set at 775 RPM. We then reset the revs per mile at 748 as recommended by TireSize.com. After we reset it to 748 revs per mile, the speedo is now within 4-5 mph of the GPS actual readout speed at 60 mph. At any rate, it appears that TireSize.com was spot on about how Goodyear does not take into account that revs per mile are not the same when it comes to unloaded vs installed onto a vehicle when under actual load.
Originally Posted by tukatz
(Post 7034152)
