Suspension Upgrade Coming
New to the forum but have been a "stalker" for the past three years :)
I plan on upgrading the shocks/struts and springs on my 2011 GT/CS vert this spring. I think I have decided on going with the Steeda Sport springs (convertible) and Pro-Action shocks and struts. I was also considering the Eibach Pro Kit with Koni oranges. I'm looking to firm up the ride and drop it an inch or so and I've read good things about the Steeda parts. Here's the question I keep getting different answers on: Since I'll be removing the struts I figured I would replace the crappy stock strut mounts and don't want to spend approx $300 on CC plates. I'd like to use the GT500 mounts and I believe if I choose those mounts I would then have to use the struts for 05-10. Is this correct? |
Originally Posted by Serenity2011GTCS
(Post 7039278)
I plan on upgrading the shocks/struts and springs on my 2011 GT/CS vert this spring. I think I have decided on going with the Steeda Sport springs (convertible) and Pro-Action shocks and struts. I was also considering the Eibach Pro Kit with Koni oranges. I'm looking to firm up the ride and drop it an inch or so and I've read good things about the Steeda parts. Here's the question I keep getting different answers on: Since I'll be removing the struts I figured I would replace the crappy stock strut mounts and don't want to spend approx $300 on CC plates. I'd like to use the GT500 mounts and I believe if I choose those mounts I would then have to use the struts for 05-10. Is this correct? Also for a relatively mild drop, you will want to run them in the correct (standard) orientation. Some people with aggressive drops turn them 180 degrees for camber correction. |
Originally Posted by 759Rider
(Post 7039279)
Correct!
(Post 7039278)
Thanks for the feedback, EF1! Sounds like the ride is want I'm looking for...not too harsh but firm. How much of a drop finally settled in after they were in for a while? Also, good point on the CC plates. Once I decide to pull the trigger on this setup I'll talk to Steeda directly and see if they can offer better pricing. I just missed out on the President's Day Sale...
Don’t forget to budget for a new adjustable Panhard bar while you are there. :-) |
Already in the cart :-)
(Post 7039374)
