Rear sway bar links (2011 to 2014)
I'm looking into a possible change in the 24mm rear sway bar links. I know the part number changed between 2011MY BR3Z-5C488-A and 2012MY CR3Z-5C488-Q. I suspect the diameter of the lower link increased. I measured the outside diameter of the lower link at 45.3mm. If my suspicion is correct, the later part might be 4 to 5mm larger. If someone with a 2012 to 2014 GT could check, that would would be useful.
This might affect the bushing kit I'm dealing with. |
