Rear Spring Isolator?
Recently purchased an 11 GT that has coilovers and I hate the stiff ride so I'm gonna pull them off and go with some lowering springs and Koni srt's. My question is are there any type of spring isolator or rubber that get used off the stock springs? There is nothing now on my axle except for a plastic piece that the spring would go around
Originally Posted by Kevn
(Post 6987034)
(Post 6987034)
Originally Posted by SGwick
(Post 6987049)
are the coil overs adjustable?
They are but the roads suck where I live and even on the softest setting u feel every little bump. No tracks anywhere near where I live so I just don't need a coil over set up |
Originally Posted by EF1
(Post 6987083)
When I installed the Steeda sport springs on my 2011, I had to reuse the factory rear upper and lower rubber spring mounts.
(Post 6987189)
OK, the car definitely doesn't have the lower one's, I'll have to check for the uppers later this evening when I'm under it. I wonder if I can get them from a dealer?
(Post 6987246)
If you can't get them from a dealer it shouldn't be too hard to find them in a local junk yard. There have been plenty of these cars wrecked over the years.
No need to go dumpster diving. Get the Eibach CS5001 coil sleeve, that's what I used because I didn't want to disassemble the stock strut assembly just to reuse the old isolators.
OP was asking about the rear mounts.
(Post 6987246)
If you have the part number you might check online and get it quicker.
Ordered them from the dealer but turns out I won't need them. Adjusted the coilovers a bit, added some lca"s and adj panhard bar and the harsness is gone. Coilovers feel like they should now, stiff but doesn't rattle everything over the smallest little bumps now
(Post 6987573)
No problem, it happens to us all sometimes.
| All times are GMT -6. The time now is 08:35 AM. |
