-   Suspension, Brakes, and Tire Tech (https://themustangsource.com/forums/f821/)
-   -   K Spring Installation (https://themustangsource.com/forums/f821/k-spring-installation-513777/)
USMC:302 Sep 18, 2012 08:30 PM
Hey all, I ordered FRPP K springs and FRPP upper strut mounts today, among other things. I've looked and can't find specific torque specs for both upper and lower strut mounts, any chance anyone has a shop manual or knows the correct lb/ft off hand? I'm plenty comfortable with suspension work, just wanted to be safe. (Will post pictures after the install this coming weekend.)
TheDivaDanielle Sep 18, 2012 08:47 PM
You'll love them! Just installed onto my Convertible two weekends ago.
dafreeze Sep 20, 2012 06:19 AM
Have read of some who were not happy with the harshness of the K's, with the 1.5" drop as compared to the P's with their 1" drop.
Link to a fully browsable on line 2011 manual.
http://iihs.net/fsm/?dir=499
If interested, I've a thread that discusses my install and complications that arose.
xUSN:302
TheDivaDanielle Sep 20, 2012 06:31 AM
Don't see mine as harsh, just a little stiffer than stock, which some might see as harsh.
autobred Sep 20, 2012 05:24 PM
front torque specs:
upper strut mounts- 26 ft lbs
strut to spindle bolts- 166 ft lbs
anti-sway bar end link nuts- 85 ft lbs
rear torque specs:
shock lower bolts- 85 ft lbs
shock upper nuts- 30 ft lbs
anti-sway bar end link bolts- 85 ft lbs
TheDivaDanielle Sep 20, 2012 06:58 PM
I swear, autobred is always full of great info.
autobred Sep 21, 2012 03:11 AM
copy and paste my dear:D
better late than never, but thanks
USMC:302 Sep 21, 2012 01:01 PM
You guys are awesome, advice, links, and honest opinions, this is exactly why this forum is the best. As far as harshness I'm not concerned, my last car was an '08 Eclipse GT on Tein coilovers that was tucking tire, the ride on K's can't hurt any more than that...
Bullitt 3309 Sep 21, 2012 03:05 PM
I have had the K's on for about 3500 miles so far with the stock Brembo struts/springs. The ride is VERY firm compared to stock. The drop is visually perfect. I will be getting the Koni SRT's down the road to soften the ride a bit.
autobred Sep 21, 2012 04:00 PM
remember to cut the top knub off (approx. 3/4") on your rear jounce stops....
TheDivaDanielle Sep 21, 2012 04:06 PM
I never cutt fronts (car was reassembled by the time I remembered) but I cut the rears.
autobred Sep 21, 2012 04:09 PM
fronts are fine,depends on how much drop you got for the rears on your K springs, mine left me with 5/8" before it hit the frame, not happening.....I just cut the mushroom head off and made a world of difference
Ordie Sep 25, 2012 12:37 PM
The Mounts are for use with '10 and older struts, not the springs. Unless those "other things" are '05-'10 struts
