K Spring Installation
Old Sep 18, 2012 | 08:30 PM
USMC:302's Avatar
Hey all, I ordered FRPP K springs and FRPP upper strut mounts today, among other things. I've looked and can't find specific torque specs for both upper and lower strut mounts, any chance anyone has a shop manual or knows the correct lb/ft off hand? I'm plenty comfortable with suspension work, just wanted to be safe. (Will post pictures after the install this coming weekend.)
Old Sep 18, 2012 | 08:47 PM
TheDivaDanielle's Avatar
You'll love them! Just installed onto my Convertible two weekends ago.
Old Sep 20, 2012 | 06:19 AM
dafreeze's Avatar
Have read of some who were not happy with the harshness of the K's, with the 1.5" drop as compared to the P's with their 1" drop.
Link to a fully browsable on line 2011 manual.
http://iihs.net/fsm/?dir=499
If interested, I've a thread that discusses my install and complications that arose.
xUSN:302
Old Sep 20, 2012 | 06:31 AM
Don't see mine as harsh, just a little stiffer than stock, which some might see as harsh.
Old Sep 20, 2012 | 05:24 PM
autobred's Avatar
front torque specs:
upper strut mounts- 26 ft lbs
strut to spindle bolts- 166 ft lbs
anti-sway bar end link nuts- 85 ft lbs
rear torque specs:
shock lower bolts- 85 ft lbs
shock upper nuts- 30 ft lbs
anti-sway bar end link bolts- 85 ft lbs
Old Sep 20, 2012 | 06:58 PM
I swear, autobred is always full of great info.
Old Sep 21, 2012 | 03:11 AM
autobred's Avatar
copy and paste my dear
better late than never, but thanks
Old Sep 21, 2012 | 01:01 PM
USMC:302's Avatar
You guys are awesome, advice, links, and honest opinions, this is exactly why this forum is the best. As far as harshness I'm not concerned, my last car was an '08 Eclipse GT on Tein coilovers that was tucking tire, the ride on K's can't hurt any more than that...
Old Sep 21, 2012 | 03:05 PM
Bullitt 3309's Avatar
I have had the K's on for about 3500 miles so far with the stock Brembo struts/springs. The ride is VERY firm compared to stock. The drop is visually perfect. I will be getting the Koni SRT's down the road to soften the ride a bit.
Old Sep 21, 2012 | 04:00 PM
autobred's Avatar
remember to cut the top knub off (approx. 3/4") on your rear jounce stops....
Old Sep 21, 2012 | 04:06 PM
I never cutt fronts (car was reassembled by the time I remembered) but I cut the rears.
Old Sep 21, 2012 | 04:09 PM
autobred's Avatar
fronts are fine,depends on how much drop you got for the rears on your K springs, mine left me with 5/8" before it hit the frame, not happening.....I just cut the mushroom head off and made a world of difference
Old Sep 25, 2012 | 12:37 PM
Ordie's Avatar
The Mounts are for use with '10 and older struts, not the springs. Unless those "other things" are '05-'10 struts
dohc97
16
Sep 24, 2015 05:40 PM
SMBJoshy
Aug 24, 2015 10:55 AM
RocStar69
Aug 21, 2015 07:33 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
