Gt500 Rear Disc Conversion
I am looking at rear gt500 discs, any advice on which brand to go for. Ford oem and centric premium seem to be a good value, which is better?
I put a set of ford oem ones on earlier this past season. They have about 1200 track miles on them with minimal wear, no surface cracking.
I had a set of centric rear rotors last season (11.8's not 13.8's) and they both had significant surface cracking after a couple hundred track miles then ended up having a propegating crack in one at about 700 miles. I've used oem and centric front rotors as well and oem seems to hold up better. I'd go oem |
Thanks for the info I will try oem.
Originally Posted by dmichaels
(Post 6954111)
Just ordered ford oem gt500 rotors. Is it ok to use my existing hawk hps pads? I know they will fit and it is ideal to use new pads on new rotors but I do not want to shell out for a new set of pads when the existing ones have plenty of lining.
